What Heads do I have - maybe a stupid question
RAYDEO
Yes V4
you see thats the thing, im getting some very conflicting info,
and im trying to avoid pulling it apart to see, as im not really in a position to be doing that sort of engine work at the moment.
not with my crappy garage anyway.
get outa my posts mr spellcheck :D
im sorta 50/50 without poping a rockercover. all ya need is a jack 10mm and 12mm.
I know the jdm v4 had the yellows, orange afm and sti ecu. suppose it would have the heads to go with the ecu for the larger rpm limit.
get us the answer ray ;)
internets gay for he said she said
+1 Shim Over Bucket. Used from 97 on.
WRX Pre 93, EJ20G, Rocker HLA (Hydraulic Lifter Assembly)
WRX 96 EJ20G, Bucket HLA 93 - 97. Shim Under Bucket also used in these years.
WRX 98 EJ20G, Shim Over, Smooth Valve Covers, TB Mounted IACV
STI 98 EJ20K, Shim Over, Smooth Valve Covers, Manifold Mounted/divorced IACV
Then onto
WRX 99 EJ205, Shim Over.
STI 99 EJ207, Shim Over.
Edited list:
STI 98 EJ20K, Shim Under, Smooth Valve Covers, Manifold Mounted/divorced IACV
Then onto:
STI 99 EJ207, Shim Under.
 rex-leggy']
theres still no way to know. whos to say its even the factory engine
Yeah, but it gives a pretty good indication of what was/should be attached OEM. :)
Does anyone know what heads came out on a 98 JDM wrx... has Yellow injectors etc
Research indicates Shim Over Bucket.
[quote name='RAYDEO said:
Sounds like alot of work... then knowimg my luck it wont reseal right and will leak... suprisingly theres no leaks in the engine at all currently....
