Pretty sure these suit anything up to V7. Pretty noob info but maybe helpful.
14038AA000 - Head to manifold gasket - 2 required
14038AA000.JPG?osCsid=5ca478c4ffb4d976ba
44022AA160 - Crosspipe gasket left/passenger side same as right side profile wise.
44022AA160.800x600w.JPG?5202f6d00996e378
44011FA020 - Crosspipe gasket right/drivers side same as left side but has a piece sticking out for some odd reason.
44022AA170 - Manifold to uppipe gasket.
44022AA150 - Turbo inlet gasket.
44022AA180 - Turbo outlet gasket.
TWIN SCROLL GASKETS TO SUIT VF36/37
44011FE040 - Up pipe to turbo
44011FE050 - Turbo to dump pipe
44011FE030 - Mani to up pipe
 evowrx said:
Nope but wack em up when you find them and ill add pics to first post. Try build up a list.
Done. ;D
Edit:
Up Pipe Gasket - 44011FE040
Down Pipe Gasket - 44011FE050
Taking a punt on the VF38 taking the same head to mani and mani to up pipe gaskets but different turbo inlet/outlet gaskets?
Yip, I\'ve had no luck finding Numbers yet though.
Ouch...Genuine through Subaru, for VF36/VF37 Twin Scroll:
UP Flange Gasket - 44011FE040 - $59.00 + GST Each
DP Flange Gasket - 44011FE050 - $65.00 + GST Each
Exhaust Manifold - 14038AA000 - $16.00 + GST Each
Edited by Rosssub
 Rosssub said:
Ouch...Genuine through Subaru, for VF38 Twin Scroll:
;D
Partsouq.com
UP Flange gasket - 44011FE040 - $13.77
DP Flange Gasket - 44011FE050 - $15.77
Exhaust Manifold - 14038AA000 - $3.60
https://partsouq.com/en/search/search?q=44011FE050
I just brought a full set, with a new OEM 10mm Oil Pump, for $185nzd delivered.
Lets see how delivery is... ;D
 Rosssub']
[quote name='Rosssub said:
Ouch...Genuine through Subaru, for VF36 Twin Scroll:
;D
Partsouq.com
8 working days from partsouq:
Many thanks for the link Rossub! I need some many seals done! Crank/rocker cover/inlet/turbos. This is going to save me soooooo much $$$$$
Now to find a parts list for a facelift BC legacy...
Sweet, Leighos pointed partsouq out in another thread. Can\'t beat those prices. ;D
Edit: Find someone else keen and go halves in the freight.
 slystiguy said:
The only thing I guess is going to be duty tax or what ever if you get to expensive.
You\'ll be all good if you keep it under $300US, besides you can always devalue it on checkout if you need to ;) Happy shopping.
  • 8 months later...
