Hey guys,
Just wanted to know if its possible to convert a EJ20 CDB to a EJ22 CDB?
Has anyone done it before? Are sleaves required?
Just thinking of options for down the track.
cheers
22 closed decks are already hard enough to find in the sates, let alone outside the sates.
All I have to ask is, is closed deck required? Surely the open deck only presents issues when doing massive power builds? For anything under say 250kw, open deck will be perfectly fine.
Will be a high horsepower build. Currently running a 2.1 CDB, just wondered if the 2.35 was another good option.
If you're doing a power build, getting a closed 22 from the states will feel like chump change. Jump on all the US forums and make some inquiries. Option 2 is boreing a 207 out, the latter will give you the more modern and reliable bottom end.
Cdb 22 arent hard to find in the uk but cheaper to close an open 22 locally and machine for rear thrust. Pretty sure thats what jon did.
Does anyone have a rough idea of what it would cost to deck an open deck 2.2 block? Or would using the 207 block as mentioned be a better option? Would the 207 still require sleaving or is there enough meat in the block to bore it out to the required size? Would it be cheaper to destroke a EJ25 or stroke the 2.2?
Whose brand of sleaves did you use? What did it cost you to have them installed? Have you had any issues with the block? What combo crank, rods and pistons were used, EJ257 79mm stroke rrear thrust crank, 97.5mm pistons (stroker or standard), standard length rods?
