1st and reverse gear
Sometimes difficult to get into these gears...usually a double pump of the clutch does the trick...
Any ideas??? ???
Cheers,
Will.
Doh! Shit! sorry...not 5th gear...I mean Reverse!!!!...and 1st gear...getting into 5th is as smooth as a babies bottom!! :-)
 thejetnz said:
Doh! ****! sorry...not 5th gear...I mean Reverse!!!!...and 1st gear...getting into 5th is as smooth as a babies bottom!! :-)
I test drove a brand new BP Liberty (Legacy) tuned by STI, and 1st and reverse were difficult...
Also my GTB does it as well as did my old grandwagon
when its being stubborn, while stopped select another gear then quickly try 1st or reverse. it should slot in.
selecting another gear like this forces the input shaft to stop rotating. reverse has no syncro and needs the shafts to have stopped rotating.
if this works, bleed the clutch. it may not be disengaging fully.
thats the cheaper fix/problem anyway. best to try it first ;)
Im quickly thinking clutch may be on the way out...it engages quite high up...its probably due as I dont thinks its been replaced yet since new.
Will change gearbox oil too as recommended...thanks...
How can I be sure its the clutch that is on its way out??? its not slipping or anything...
Should I drop it into a garage...? Highbrook auto is out my way...
1. Change gearbox oil
2. Bleed the clutch..
3. Replace the clutch?
What should I be paying for a new clutch on a BL5 GT??
Have heard of that before... Hmmm will try
Guest lan_killa
I had a similar issue on one of my other cars... was impossible to select a gear when stationary with out pumping the clutch pedal a few times
Turned out I had a small leak in the hydraulic system for the clutch meaning the pressure exerted in the master cylinder wasnt making it all the way to the slave therefore the clutch wasnt fully disengaging, low fluid level can also have a similar effect
