Hey everyone I own a 03 STi that has a centre diff whine, I’m going to do an oil change ect to hopefully stop that before digging deep into my saving to do a replacement. What oil do you’s recommend?
thanks a lot 🙏
The whine gets loud around 2.5k rpm in second, 3k rpm third gear and so on. I have seen videos and talked to a mechanic on the topic. Either way no harm in doing a change and starting there. I might try get a video of it at some stage
Actually, I misread the original question. I'm not sure exactly what fluid the center diff takes; whether it shares it with the gearbox or what. Presumably yours is DCCD which also complicates things.
I never got whine from my DCCD that was worn.
I did get a lot of whine from the gearbox bearing wear. But that also has the gear shifter move when you accelerate hard or lift off at higher rpm.
