Brembo conversion - quick question.
Shale
Are all four hubs required for bolting on Brembos (considering it is 5x100 now and staying 5x100), or can I get away with just using the rears?
Reason for asking - just spotted an opportunity to grab some, pricy if I go for all four though (grand for a set).
Fronts will bolt straight up to your existing setup, rears will need the hubs.
yeah im getting me a set also! but its coming with the hubs, but tis 5 hours drive to pick them up each way as they wont send it from Taranaki
Bit like when us crazy Jafas go to Tauranga to pick stuff up :P
Just getting the rears is gonna make stuff way easier - still gonna rip the front of the car apart anyway, because there's some alloy arms begging to go in.
Fun part is going to be watching the car get even slower for a while, while the poor little 20E drags around extra lard from the GDB bits. :-[
yeah i was told it can be done. awhile back ago i sold a set of rear 2 pots to someone in chch and he said he just made the adaptor for it
I have a guy in taranaki who could pick them up for u
then we should be able to get them sent :) maybe depnds on how much u wanna pay fo shipping
there is also some guys on here from the 'naki also
you, IIRC, need type-R rear hubs? as the GDB ones will be too wide? someone correct me here?
  • 4 weeks later...
Thread bump.
Okay. HYPOTHETICALLY SPEAKING...
Type R gearbox + Type R rear diff + Brembos (incl hubs) + ______ halfshafts = yes?
Blame Funky.
Ninja edit: Anyone in Auckland able to give me a demo of Type R gear ratios etc? They are closer than my puny failbox, yes?
as i said in my Pm.. and care of Optical.. (so blame him)
You can run the rear brembos on R160 hubs.. the type that take the two pots. you need the special Rotor for the brembo caliper.. (bigger) but takes the smaller R160 handbrake.. DBA do such a thing. then you just bend the stone gaurd a bit.
Rule of thumb -
R160 or R180 required the same in axles/diff/hubs. ie all three bits have to be either R160 or R180 (assuming you dont modify anything)
(info all care of optical.)
 Shale said:
Excellent info. Either way it's a conversion for me hence looking at the genuine hubs - I have single pot rears at the moment (version 3 STi).
Sounds like an option though.
same here.. im on single rears.. You do need the R160 hubs that at least take the two pots to do what is mentioned about. so il have to change mine out for the newer R160 hubs
Rule of thumb -
290mm disc with a 170mm handbrake hub. Off an 01' wrx if you go through Ripco. Not cheap though.
Thats if you run an adaptor with the r160 diff.
