i read it takes 4.5 l to fill i ended up putting in 5 litres with a bit of spilage will the extra oil be bad for it?cheers
Guest iceboychch
next time use a funnel :)
stops the mess. :)
yeh it seems to be past the full mark should i take some out?
How far past the full mark. Just a few mm higher doesn't really matter. Thats usually where mine is filled to and I often use between 4.75L and 5L when filling up.
I usually put in 4.6-4.7L to take into account for oil getting stuck to the side of the funnel/container/etc. I've accidentally over filled it before and on both occassions it was followed by a leaking crank seal.. could be a coincidence, but I'm very carefull these days!
Guest sleeperfoz
i just tip the whole five litres in ;D
mine runs abit of boost with no catch can,so it breaths a little. :D
so it loses the xtra over about 10k and then change again :)
