How much does it cost to replace a cambelt on a B4 RSK please?
I have been quoted about $900.00 which includes standard service as well......but I;ve heard some places charge much more $
Been given different quotes ranging from 750 to 1000+ (including some or all of the service) Pays to check with a few different mechanics.
 QUIKGT said:
All depends on what you want replaced.
Cambelt only - $350-ish.
Idlers, tensioner, waterpump, cam & crank seals etc too - $1000 easy.
ALWAYS DO THE CRANK SEAL.. check that they do ... most good mechanic's will do it but there are some that wont..
won't get much change from $1100
Guest Rugged_RS
I payed $1050 for the lot when i bought my RS, but he cuts my labour costs a bit for me soooo.... prob wuda cost about 1150-1200?
Damn I was $950 and that was thru subaru dealer, which are usually more expensive then most places. Which was also the lot.
Mine was about $1100 for the lot.
Idlers, tensioners, front crank seal, waterpump, o-ring etc.
Its worth getting it all done cos you don't want to have to open it up again to fix an oil leak!!! My WRX had just the belt done, and it leaked more oil than a '72 jag.
im sure there is heaps of people on the forum that would do it cheap... i have also a couple of friends that are mechanics that i am sure will be willing for some extra cash.
im about to do a twin turbo bg5 and just bort all the parts eg waterpump seals idlers tensioners auto gas tensioner and belt plus new alt and p/s belt for 450 and id do it 4 600 all up.
  • 2 months later...
I got quoted $450 at sub dealer in Palmy North
Was that 1st Automotive, or maybe Elite automotive?
 DPI']
450 wouldnt even get you all the parts required....
it would get you a new belt....and a bit of labor!
Cant say id trust the job being that cheap
i can get all parts required... belt, auto tensioner, cam and crank seals idlers and waza pump for 550 from repco ad thats like cost plus 20 to them! so anyone who can do it 4 450 id be watching them do it... haha theres atleast 3 hours in a cambelt seals and waterpump.
 boostcut']
Im with boostcut & keltik on this one
I got mine done a manukau subaroo specialist and was quoted $950 but ended up being $900.
Paid 'bout 1200...that was cambelt, waterpump, idlers, tensioners, hydraulic tensioner...also had all the accessory belts done at the same time and seals checked as well....
Whereabouts was that from suubyduuby???
Perfect Power Ltd
123 Kerrs Rd
Manukau
I have dealt with Jack (the owner) and he's always provided excellent service and a great job.
He also has a 4-wheel dyno as well ;D (And does dyno tuning)
  • 4 months later...
 DPI']
Was neither of them. It was the actual subaru dealer. They quoted me $450 for cambelt and tensioners and labour
