2005 v10 subaru sti hard to start when cold
subiesti
have been too busy but think that it is the battery cause all the cars that we have owned do this after 3 to 4 years of age and if its 0 degrees outside its a lot harder to start. Has ur car had a new battery yet? 8)
Not yet, still on the original one that came with the car when new :), might be on its way out, seems to start fine during summer. Does your cranking become slower making it hard to fire up with the colder weather out there?
yep mine slows down alot when cold think i have ta get new battery before we get -10 degree frosts otherwise it will stay in the shed 4 winter. and i want to do some driving in the snow. So batteries only designed to last 5 years normally even big tractor battories 8)
  • 2 months later...
a small update... i just got a new 550cca battery for my v9, still the same but do notice it does crank really strong due to the new battery... another thing i found is each time i disconnect the battery, reconnect them, starting the car up will be instant none of that cranking then start ... ???
Got any reccomendations on brand of battery to go for? My one's almost shagged and my car has been a bit sluggish...
Guest the_return_of_the_jedi
if u want a decent battery you be lookin at $100+ make sure you get a 12 month warranty as well :)
Just get high ccas. A heavy duty no less than 350cca will do you for awhile. Mine has a 550cca with a 90min reserve. Cant remember what brand. Cost me $130.
Think its a champion. The GTB has a repco heavy duty in it with 330-340ccas.
ECU start proceedure, = coolant temp and crank signal, no other sensor is used for initial fire up
possible system is logging codes, and you disconnecting battery is clearing codes and allowing start straight away
get dealer to check codes and temp sensor calibration alignment
prob around $30 to check codes
Temp sensor around the $80 mark plus fitting
Crank sensor around $120 plus fitting
Costs are from memory, call a dealer and ask
make sure battery is all good and terminals are well secured too
battery are brand new, terminal are definitely secure
i get them to check for the codes
crank sensor are easy to change,
coolant temp sensor <--- do i have to drain the coolant?
so i assume the price for both sensor are pretty cheap :)
I bet on Marshall/exide,This comes from 20 years of diesel experiance
I would suggest a NS70 (or NS70L I cant remeber which way around the terminals fit)
It is the biggest battery that barely fits in the hole :)
