94 WRX Electrical Issues... IVE HAD ENOUGH ITS ABOUT TO GO OVER A CLIFF
Guest lan_killa
Guest lan_killa
Hey guys...
You may remember i had a thread up here sometime ago about electrical issues in my WRX, well we never got them sorted, so Im going to ask again.
Problem:
Looses spark randomly, but only when warm if driving in the middle of the night it runs mint, middle of the day... not so flash. This is not a missfire it is a complete and total lack of spark. Will do it at any time, idle, deceleration, acceleration, cruising or even wide open throttle. Duration of loss of spark can be anywhere between 1 second and 30 seconds, sometimes it wont even restart. Very occasionally i will get a CEL which comes back as air flow meter, but i dont get it every time.
Remedies Tried:
-New AFM
-Second hand Cam and Crank angle sensors
-Second hand ignitor
-New Coils
-New Plugs
-Additional earth leads from battery -ve to block and inlet manifold
-Additional earths for the ECU from the inlet manifold. (as described on the last page of the possum link installation manual)
-Second hand TPS
-Have sprayed contact cleaner through every last connector I could find
-Have found that I can unplug the AFM and it stops this cutting out nonsense, but then ends up in limp mode and doesnt run particularly well.
Please help me with this... I have really really had enough of this, its been going on since easter last year... am seriously over this car, want to get it running and sell it so I can get something else, in its current state it will never sell as I can barely drive it to work and back.
  • Replies 96
does the dash still light up etc, just no go?
theres the temp sender in the airflow meter? ( dont remember for sure ) cable from that damaged?
just thinking of the temp thing in that coz you motioned ok at night :) coz its cold at night lol
-smurff
Guest lan_killa
when things are cool (ie night) it runs mint... when its a warm day its a complete sack of ****...
dash still sits there doing its thing, have noticed when it stalls it takes a good 4 or 5 seconds before the CEL comes on after stalling
BTW this doesnt make sence
any idea why ur abs threw a wobbly?
was about your map sensor? that could cause to run bad and if i unpluged mine ( the electrical plug ) it would stop the car.
-smurff
Guest lan_killa
abs is always odd when you activate it in my car... it is and older setup and uses a g-meter to determine what to do.
dont think its map... if i unplug a vac line i just get limp mode
u could try running a new power wire for the coils? my leone did this sort of thing and that sorted it, although it is a very basic setup compared to this. you really need to do some tests as soon as it dies to see if it is a power issue etc .. but running a new wire will at the very least eliminate it as the problem
Guest lan_killa
should have more than enough earthing now
the Leone and the WRX are very very different beasts wiring wise (i used to have a leone too) remembering I have 4 coils and each coil has 2 wires to it
Dont think its water temp, ive had logging software on it, and can produce a log if you like and the ecu reckons the water temp is around 95degC once at normal on the gauge
Guest lan_killa
ok heres a log for you to look at
http://homepages.slingshot.co.nz/~moliver1/WRXbad130210.csv
Points where it stalled
Car was sitting idleing in driveway
LogID 101 looks to be where the stall started to occur
LogID 104 - 116 note RPM showing 225 (engine was deffinatly stopped)
LogID 117 Restarting engine
Just after reversing out of driveway
LogID 144 - 145 Car stalled
Started driving off down road
LogID 162
Theres a few other weird things in that log which you may pick up on.. but having a quick scroll through is seems that the knock correction is all over the place... 17 at idle yet was down to 1 at LogID 269 and was up as high as 45 at times
got ignition advance of 31 at LogID 141 and upto 45 at times
Are you sure its coils losing power? The AFM shares its 12V supply with the injectors. Maybe that feed is dropping out?
Just an idea, run a few leads back into the cabin with some LED's connected to things like AFM 12V, coil 12V etc, so if it does die, check the LEDs to see what has dropped out.
An issue that comes and goes with temperature usually indicates its a connector opening up and breaking contact. Have you done the wiggle test of all the connectors in the engine bay?
Guest lan_killa
that led idea sounds like a plan
its hard to tell with the wiggle test as its an intermittant fault anyway...
Got a pin out for the green afm?
Found it!!
1. Yellow/blue - 12V
2. Black/green - Earth
3. Black/green - Earth
4. Pink/blue - Signal
5. Yellow or yellow/red - Air temp
Both earths link back together and run to the ECU.
Guest lan_killa
ahh hah... mint
so what should I be putting LED's across??
-AFM
-Coils (or ignitor?)
-ECU
-what else
Oh and today i changed alternators to a spare one I had floating about... did notice that my stereo doesnt whine when the alt is disconnected, but when an alt is connected and the car running the stereo whines quite a bit
I would go AFM, ignitor and coil, and injectors. I say ignitor and coil as it will check the connector between the 2.
