94 WRX Electrical Issues... IVE HAD ENOUGH ITS ABOUT TO GO OVER A CLIFF
Guest lan_killa
  • Replies 96
It's a weird one like that, I thought fuelling too but Matt pointed out that it would likely splutter like fuel surge, rather than simply drop out entirely.
At least you've seen the car at its finest, stalling out everywhere ;D
Guest Fastfour
Flic did that for a bit. Started and ran alright then after a few minutes sounded like it dropped a cylinder and ran like shet then died.
Worked out that something in the alternator was a bit funky. Pulled it apart and cleaned the thing up and it was ok again. Was undriveable when it did it too.
lol, yea the whip lash was nasty, lol.
Perhaps a dodgy cam or crank angle sensor
 boostin said:
Det doesn't make the engine stall and then not restart.
I've seen it myself. Idling away nicely in the drive, then coughs and stalls, and won't restart for a minute or so. There was no det while idling!!
Just throwing ideas out there bud. He said the cutting out issue is there cruising, accerlating etc NOT just at idle.
In no way what i am suggesting meant to be the "bonified" fix, i just know that if i had a car that logged data that hinted at knocks being detected & highly advanced timing etc, i would be investigating that further, especially when every other thing thats been tried has failed.
i think they call that a process of elemination ;)
Guest lan_killa
ok, sorry I havnt been on in the last few days... been a bit sick
So... in the mean time I decided to install and setup the possumlink ive had sitting around for a while... and suprise suprise there is no more cutting out, so Im thinking my issues may have been somewhere in the AFM wiring... but the AFM is now unplugged as the link doesnt require it to run.
Got a couple of small tuning issues to sort out but otherwise it looks like its all rock and roll
Have also noticed my alternator making some real funny buzzing noises, and have always had a bit of a whine through the stereo, but I think the stereo whine is due to the amp being rather fuc*ed... the alternator buzzing is a bit concerning though
is that the alternator i dropd off to you? did i drop you an alternator? i cant remember now
-smurff
Guest lan_killa
yup... thats the alternator you gave me... I only got round to sticking it in about 3 weeks ago... didnt make any difference to the running of the car back then
 lan_killa said:
BULLCR*P... you just give away broken sh*t
LOL! only to you :P;) everything else ive gien away seems to have worked, except for a starter motor i gave to stimomo, that died 6 months later the day he sold the car lol
-smurff
Guest lan_killa
btw one of those green afm's you gave me was a nissan one... so that would of never worked anyway ya plonker :P
Guest lan_killa
it had a huge bloody nissan logo on one side... I ended up giving it to wingers when they got me a replacement one so meh
  • 8 months later...
damn you had the same problem as me, I spent many dollars on my engine and then the last thing I didnt look further into was the tps, it sometimes out of range, it was a bastard of a problem I gotta second hand one but it did the same. but with all my tinkering, replacing knock sensor, replacing fuel pump even wastegate actuator all made my car better in the long run, I had my car hooked up on some scanner and it was reading the outputs of my sensors like the tps, he reckoned it was dodgy again but by then gave up with it and replaced engine and ecu with a v4 sti engine.
Did you check the last post date, and the OP? Dude's deleted himself (lol ragequit) and the thread is nearly 9 months dead... ;)
