slystiguy last won the day on October 30 2023
slystiguy had the most liked content!
Drives :
As a volunteer Sheriff’s Deputy I’ve been doing surveillance for years. One time I suspected an ex-girlfriend of mine of cheating on me, so I tailed her for six nights straight. Turns out… she was. With a couple of guys actually, so… mystery solved.
Interests
Cars
Location
christchurch
Occupation
aspiring freelance bodyguard
3,620 profile views
slystiguy's Achievements
Old Boy (5/7)
290
Honda makes a throttle body converter thing, basically connect up your cable throttle to this honda part which is like an isolated box which outputs throttle input to ecu, then the ecu controls the DBW throttle (e.g when putting a ez30 engine into a cable throttle vehicle). It saves you converting the car but does require spare ecu inputs etc . Also seen people weld in the DBW pedal assembly into the car but takes a bit of time getting it setup correctly.
Rumor has it Subaru NZ buy prices are worse than partsouq. Makes you wonder how/why it's like that and how many middle men are clicking the ticket along the way to see a 200-400% difference in pricing. They do some competitive pricing on cam belts though!
Could be a number of things. Is the car jerking and back firing at all? Is it a hesitation or a miss? Does the idle run rough sometimes, or dip up and down? What does the boost gauge say? Is it still building boost up top? The not wanting to start when hot thing, it's common for that to be the ecu temp sensor which is on the under manifold cross over pipe. Cheap to replace, kinda a pain to access on some models. If that sensor was faulty it could be reading a false high temp and trying to save the engine? I don't really know how well these old ecu's worked so may not be that intuitive. IME on that model it's usually coil related, cracks in them etc. Check coils for any cracks under the rubber boots too. As a quick fix you can fill the cracks but the v7 coils is a good mod. And check the wiring isn't questionable too! Intake - these models are prone to cracked and damaged vacuum hoses, some may not be sealing properly anymore. A leaking intake pipe, or gasket might be losing boost pressure as it builds higher. You can pressure test the system after the airflow meter. Also BOV leaks are common. Coils - This model crack coils often, check wiring to them as well. AFM - These are prone to failure on setups that run pod filters, in my experience they generally make the car run rough rather than miss so wouldn't go grabbing one just yet Detonation - Is the car running proper fuel? E.g 98 or 100 octane fuel. Is the intercooler doing it's job properly? Are the fins bent to s*** and stopping cooling or is the bonnet vent for it still on the vehicle and pushing air on the cooler as it should. Fuel related - A tired old fuel pump not keeping up later in the rev range as pressure drops, or an injector not flowing correctly, or even a pressure regulator not working or not recieving vacuum. Also the wiring for these pumps is known to fail and give issues, a common mod is a rewire of the pump and use the ecu to turn on a relay. Good luck ?
That coupe is a gc4 so yes it is a Retna car. Sadly it's been completely wrecked by who ever did that to it. Sad day for Retna fans and s201 fans alike. Why would you bother converting a coupe to that spec when it effectively makes it completely worthless. As ugly as the s201 is, I'd still respect someone who took a crashed one and swapped it to another 4 door as a replica or just to keep it from going off the road. The doors /body has had the lines removed too so cannot really be made into a type R without considerable body work. It's a pretty big derp from who ever owns it/built it.
https://www.trademe.co.nz/a/motors/cars/subaru/listing/2812433626?tm=email&et=45&mt=B9322494-2FDD-4FA1-8CD2-7777824C2ED7&bof=dDlnfzvz
If it's a car you're going to keep/enjoy/modify then probably worth selling and getting an sti just for the 6 speed box reliability factor. A stock wrx will still make good gains and drivability when tuned. The good things about those particular cars is you can swap the sti parts and make decent power on them. For example sti injectors, sti turbo, uprated fuel pump, turbo back exhaust system, sti intercooler you should hit that 300hp mark or close to it! There are a couple different models of wrx, some come with bigport heads and some with small port heads. That being said @Timmah has a v8 wrx and he's making some decent power around 300whp. Maybe he can chime in and let you know. Sti will also hold it's resale value much better
as long as the ratio is the same you will be fine
Braided brake lines for V7 brembos into V3 type r
slystiguy replied to chunky's topic in Impreza, Crosstrek and XV
Just get them made at like any brake shop. Or message Braketech and he can make some up for you/sell you the correct kit https://www.facebook.com/Braketech/ -
V4 gc8 boost control selenoid piping 3 port
slystiguy replied to DVLDDY's topic in Impreza, Crosstrek and XV
As a temp fix, run a piece of silicone hose from the turbo nipple to the wastegate. This will stop the over boost. Subaru's don't like over boosting so I wouldn't be driving it hard if it's boosting too high. I think we will need a photo of your setup to provide more information. A 3 port solenoid is probably more capable than a factory boost setup, but it requires aftermarket support or retunes. It's not necessarily a bad thing to have. .. Here's some info on factory plumbing for you -
Rather than replace the injector get it flow tested with the other 3 that will tell you if it's working properly or not. Is the wiring to the coil getting a solid 12v with ign on? Wiggle the plug/wiring on it see if the voltage changes might be as simple as a dicky connection. The coil should have 12v and each time it's fired it is grounded by the ecu. If it doesn't have 12v then you most likely have bad wiring or something. Move coil to different cylinder and see if the problem remains on the cyl 2 or moves with the coil. If it remains it's probably wiring or ecu related, or worse case something wrong with compression etc. And if it moves with cylinder then replace that coil and see if you just got a dud coil.
3.0R vs GT for daily driving fuel efficiency
slystiguy replied to willisnz's topic in General Vehicle Discussion
this topic is over 2 years old lol -
Yea all bolts up. You can't swap the rocker covers but I think you can run v1-2 coils and they fit? Or with wiring mods it's easy to run later model coils or wasted spark setup. I've done it if you need more info. What spec is your current setup? Exhaust, intercooler, boost control, ecu, fuel pump ?
How many wires are on it? On some gauges they have 2 power wires, 1 runs to power and another runs to a switched headlight source (so they dim when you turn headlights on). I'm assuming you want it to not have power unless the headlights on turned on? You have a few options for power sources ACC power - Same as stereo power, so turns on with the first click on the ignition key turn ON power - This will turn on the same as power windows work, only running when the key is turned all the way, or the car is running Switched via headlight - This will turn on only when the headlights are turned on, the same as the backlights on dashboard switches are illuminated when the headlights are turned on You will need to use a volt meter to find the correct source to suit your needs, you take take headlight switched source from the likes of the back of switches on the dash, ACC and ON can be sourced from the stereo wiring.
Won't your IACV hit the bov?
My bet is a rod bearing. Hard to say from that video... Doesn't sound good...
Who's Online 0 Members, 0 Anonymous, 164 Guests (See full list)
