Subru
Springs/coilovers. Decisions, decisions :P
20 posts in this topic
Was going to get springs but after more research I dont know.
arrgh... so hard to choose between coilovers and springs I want it lower, literally just 2cm in back and 3 or 4 in front but I dont want it to handle any worse (some ppl think lower springs could make it handle worse) and springs might not give me the correct high but coilovers are very expensive...  springs cost around 500-600 but I could do it properly and spend 1.5-2k getting adjusties and cert.. I just dunno, any thoughts? xD
Share this post
Link to post
Get some used springs. Are there some STI pink ones that would do what you need?
Then later if you do a few other mods together that need certing, you can get adjusties and do it all at once; you'll get most of your money back on the springs.
EDIT: $2k is a lot of money to spend on something that may make your car handle worse.
Share this post
Link to post
What's your future goal? Tracking it at all in the future? Springs are nice for daily driving. I daily drive on coilovers with my Subaru but the only advantage is just raising and lowering it to suit my liking, just because I don't track my car and no plans to do so anytime soon.
Edited by BeastGRB
Share this post
Link to post
how much lower it be with sti pinks?
Daily driving, not intending on tracking it but want a nice looking car that also handles well. There is too much gap atm.
Share this post
Link to post
If you buy used springs on struts from subaruspeed/strongs they usually give arch height so you know how its going to sit.
1 person likes this
Share this post
Link to post
https://www.subaruspeed.co.nz/collections/struts-and-hubs/products/strut-set-impreza-01-03-2wd
theses are the only ones that will fit I think. These a good set? My current struts are the pink ones I think, are these the same struts or doesnt it matter?
Share this post
Link to post
3 hours ago, Subru said:
Yep, H&R are good brands. They are very comfortable while still providing the drop look. 35mm won't be 'sacked' but for the purpose that your wanting I reckon these will suit ya. I have a mate who owns a Honda Euro R which has H&R and he swears by how comfortable they are. Probably worth to ask if they would still sit captive with your current shocks?
Share this post
Link to post
Sweet, yea I might try find out.
Share this post
Link to post
4 minutes ago, willisnz said:
Do STIs not come with pinks stock?
Pretty sure mine are pink, the springs are not the pinks tho im pretty sure.
Share this post
Link to post
Here's my car on 17x7 with STi struck and STi Pink springs:
The rear sit lower compared to the front sadly giving it the "saggy butt syndrome" - I do plan on fixing this by getting some spacers.
Share this post
Link to post
ohh nice, I just brought some H&R springs yesterday so I hopefully get em this week sometime.
2 people like this
Share this post
Link to post
The trouble (unless I'm looking in the wrong places) is finding a spring that has an equal or higher spring rate than the factory V7 STI springs, without giving to much low.
Edit: and then finding someone who sells them, usually importing them, all while keeping it affordable.
Edited by calebwrx
Share this post
Link to post
is the rear really sitting lower if you measure from ground to jack points?  my front and back are equal height from ground to chassis but arch gap is quite a lot greater up front than in the rear, though this might just be a bugeye design issue (or intential, dunno)
1 person likes this
Share this post
Link to post
I should get off my butt and check, but I think you're right, it's just how the arches are designed which gives it that look
Share this post
Link to post
Suggestion, Have just brought both front and rear sets of Monroe shocks, Tein or H&R springs?
Share this post
Link to post
H&R springs only at this point. May need shocks tho. why?
Share this post
Link to post
Was just thinking, If you're wanting more of performance but not wanting to go all out on the adjustable suspension replacing the shocks could help alot with the handling. Was just a passing thought.
I now need to decide if im going to go with H&R or Tein
Share this post
Link to post
I've got Tein springs on mine, ran that for awhile.  Performance over stock was noticeable.
Then upgraded to Whiteline adjustable rear sway bar and Anti Lift Kit, now the car handles great with a massive reduce in body roll.  I don't track my car so that was the perfect balance between performance and comfort.
Edited by yoUaReABUS
Share this post
Link to post
