  • Upcoming Events
    No upcoming events found
  1. General
    1. General Vehicle Discussion
      General discussion board for anything car related
      103k
      posts
    2. Stolen Vehicle Register
      If your missing something or have information about things lost
      4.9k
      posts
  2. Knowledge Base
    1. General FAQ (Read Only)
      Non-model specific frequently asked questions relating to Subarus. (Read Only)
      If you have something to add, contact one of the Mod team (Full List HERE)
      43
      posts
    2. 80.1k
      posts
    3. 87.7k
      posts
    4. Legal
      All things regulatory, WOFs, Standards etc
      2.9k
      posts
    5. Motorsports
      Track day and MSNZ specific discussion
      1.8k
      posts
    6. "Other" Tech Questions
      discuss anything non Subaru related, your tools or how to fix a Lawnmower in here
      649
      posts
    7. Product and service reviews
      Share your first hand experiences good or bad.
      339
      posts
  3. Regions/Events
    1. ClubSUB Events
      Only things we're involved with such as Flat-Nats
      9k
      posts
    2. Auckland/Northland
      General discussion board for all our Auckland/Northland members
      Moderator : ADIKT:
      17.9k
      posts
    3. Waikato / Bay of Plenty / Taupo
      General discussion board for all our members in the Waikato, Bay of Plenty, King Country, Taupo.
      Moderator : nztintin
      2.1k
      posts
    4. Taranaki / Whanganui
      General discussion board for the Taranaki and Whanganui areas
      25
      posts
    5. Manawatu / Wairarapa / Hawkes Bay
      This team represents the East Coast, Hawke's Bay, Manawatu, Poverty Bay, Wairarapa-Bush areas
      5.4k
      posts
    6. Wellington / Kapiti
      General discussion board for all of our Wellington and Kapiti based members.
      Moderators : Chulozumo & Sc00byd00
      10.5k
      posts
    7. Nelson Bays/Marlborough
      Topics relating to Nelson Bays/Marlborough
      Moderator: VACANT : apply within
      76
      posts
    8. Canterbury
      From Timaru to Kaikoura, the Port Hills to Mt Cook, Its all Red and Black here!
      11.7k
      posts
    9. Otago / Southland
      General discussion for all our Otago / Southland based members.
      Moderator : Tydon
      7k
      posts
    10. Outside NZ
      Post & share your international events & see who's active in your Neck of the woods
      18
      posts
  4. Classifieds
    1. Car Exchange
      Buy / Sell / Trade vehicles
      post
    2. Parts Exchange
      Buy / Sell / Trade car parts
      post
  5. ClubSUB Shop
    1. ClubSUB Shop
      The place to go for Subscription purchases/renewals, stickers, banners, t-shirts and anything else we can get our logo on.
      posts
  • Member Statistics
    8,630
    Total Members
    1,713
    Most Online
    Tyuru
    Newest Member
    Tyuru
  • Who's Online   0 Members, 0 Anonymous, 101 Guests (See full list)
    • Pretty much. The board and chip can read any can up to 1Mb/s speed what you do with it is open to how much coding you can do. The ESP32 that it’s based one has built in canbus support so it’s not as complex as it appears.   I’ll have some basic framework coding for it, along with the web config examples. That way there is no need for an app as the ESP32 can be a wifi access point and you connect to it, and it shows the settings. I have two prototypes running on the OEM stock canbus. One does rpm shiftlight the other is DCCD display. The tire pressure one hasn’t got off my desk yet as it has an annoying mounting system but it works, mostly. There is no discovery scan yet, you have to know the max addresses of the sensors. There is another bigger display that is popular CYD 2.8” with touch control for NZD$15-30 as well, that seems like it maybe a good idea to do as well. Power and canbus would be 1/4 to 1/3 that board the rest could be holes for whatever other electronics.
    • So, these little gauges can hook into the CAN system and then ... read whatever? Clever! Another reason for me to get a Link..
    • Have a week or two before the first version turns up and no improvements to make until I can test the board.   In the meantime I had the idea I could adapt what I have to a board that plugs into this… https://www.aliexpress.com/item/1005008877505362.html that way it’s really cheap to have a canbus connected mini display.   Anyone can cut or print a custom front panel or mount it behind a small cutout. Only a few screws hold it together which makes it simple to assemble. Being shipped from China as DIY no need for certification like CE or FCC for radio(wifi) devices. That board already has 3 usable buttons (plus reboot) and 3 spare in/out with serial port. 2 is enough for canbus board. It has place for power in so I just need to do a 12v to 5v section and the protection circuit.
    • Boards have the pins labelled and aren’t locked to custom firmware so can be reprogrammed by anyone.   So far estimate around NZD$50 with the LEDs in case as shift light. Main 3 chips are around USD$9
    • Well ordered the first circuit boards for prototype 4.   WTF cost was USD10 shipped for 10 custom boards.   It is insane what you can fit into a tiny space. The board is 20x76mm and max 5mm high with all these features:  now 1cm longer and added reverse polarity protection. Plus no need to replace diodes for 24v vehicles.   fuse, self resetting short-circuit aka reverse polarity protection  12/24v switch mode power supply for low heat 90% efficiency  Just need to swap the fuse for use in 24v vehicles Optional ign switch input to power up Electrical power noise filtering Electrical filtering ADC pins Spare 5v and 3v3 volt outputs 4x static (ESD)protection for buttons and knobs etc 12 general purpose input/outputs Current generation CAN 2.0 controller with listen real listen only mode.  CAN bus noise filtering, ESD and voltage spike (TVS) protection optional canbus termination for aftermarket ecu 2nd bus use. ESP32 module with dual core cpu, wifi and Bluetooth  connector for firmware update and Arduino IDE supported This is massive overkill and parts are high spec low tolerance ones. board can run as almost anything, supports full LCD displays etc.      Adding web configuration for colour of each led and rpm it triggers at, mostly done. You can set can ID and bytes via web to look at so supports most cars and aftermarket ecus.  Also want to add an aftermarket mode that allows ecu to do some cool things that I have seen any other product do.
  • Latest Products
  • Popular Contributors
    • Total Topics
    • Total Posts
