car wont start after installing split fuel rails....
zarnah
just finished installing my yellows and split rail setup and now my car wont start. seems to be something electrical because When I turn the ignition on I cant hear fuel pump start up, pulled fuel line off filter and no fuel coming through. also I noticed when I turned the key off my dash lights stayed on just very faintly but they wont turn off so I had to disconect battery. anyone know whats goin on? car is 1993 gen1 facelift
  • Replies 50
Guest SPANKU
ok. did u make sure that the seals around the injectors are in properly? see if u can smell fuel from the exhust? u might be flooding ur rail?
u ussing any after market ecu to run the injectors?
check if u got the feel and return right?
Guest GOTBUD
 SPANKU']
[quote name='zarnah said:
as said the fuel pump isnt going at all no fuel is even making it to the rails.....
LOL 90 posts still can't read classic
yeap shes all go now! using a aftermarket fuel pressure reg though and I forgot to set it so went for a burn down the road and went mint untill I heaed a "pop" and started running like shit wouldnt go over 2000 rpm. got home and popped bonnet and a fuel line had popped off, turns out the reg was running nearly 70psi lol cant have been to good for my new injectors
that bad huh? didnt really think of it catching fire, just limped home popped the bonnet and saw fuel spraying everywhere and thought "meh, stupid hose clamps" lol. guess I owe the big fella a thankyou....lol...
 funkytown said:
like... holy crap batman...!!! ??? ??? ???
go buy yourself a scratchy from the lotto shop
aha - why do ppl always think its lucky to have a close call like that!
I think the opposite - you were unlucky for it to happen in the first place! (or to lay blame stupid and lazy for not doing it right in 1st place...)
glad you are sorted and safe now thou :]
next problem-car is now running like an absolute sack of shit, running really rich can smell it and bit of black smoke coming out exhaust, really rough idle to the point it nearly dies, then every now and then it just starts iddling normal again. any ideas?
 rockr said:
if ya were running 70psi before it blew off , could quite propbarby fouled the plugs up.
+1
Remove plugs and heat with butane torch until the white centre electrode porcelain (now black with fuel soot) turns white again
and set base fuel pressure to 45lb with vac off
