if you want the guards rolled (lip i assume you want) my brother may be able to do it for you if he has some time.
as for guard flaring, this will damage your paint, so is doable, but you will need to do some repainting.
-smurff
Or and as horey as it sounds just use a cricket bat (handle end) with the wider tyres on there and roll the car back n forward slowly with the bat between the guard and tyre ... Seen it done n seems to work wat do you expect westies save money where possible lol
 GC8E2DD said:
dubbedup suggested the same thing. Would you heat the paint first?
gently - but if your impatient it still cracks.
spending $$$ (and it costs plenty trust me) is the only way to do a real nice job.
we rolled my guards with a jack handle - then touched up inside the guard with clear nail polish to stop extra paint chipping off
 LAZLO said:
smurff how much would your brother do it for
i can ask him when he gets home, he has a rolling tool and also the little hammers for odd spots
-smurff
just talking to my brother, he says 2 gaurds $40 all four $80. he is moving house atm though, so may not be able to do anything untill he has moved.
Pm me and i will give you his number and he can fill you in on any details. he is in pakuranga.
-smurff
that is to have the guard rolled, if your after a flare, this will have to be discussed as it involves paint damage. if you want his number PM me.
-smurff
I beleive it's still factory ride height. I spoke with mag and turbo and they stated that only a 18x7.5 is max that will fit without modding anything. Then other people I know who have worked with tyres before say a 18x8 will fit so I'm quite confused.
And smurff, I'll keep that in mind.
i guess tyre size also plays a part, you have big tyres more chance of issues
-smurff
 Enervated said:
Where'd you get yours from?? mag and turbo seem to bulls*** I think.
They probably play it safe given that they dont want to send away a customer with a product that isnt fit for purpose.
Then again, I might be over estimating the intelligence of your average Mag N' Turbo worker!
It's probably because that is what they are told by the wheel manufacturers. You should be able to get 18 * 8's on there fine, there is probably just not many will actually be advertised officially as being able to fit, hence why shops say no.
