Opions On 400hp at all fours :P
Enervated
  • Replies 62
to many variables in what your asking above man.
do you want the block to dial in 400hp and explode or is it for a 24hr endurance event? What turbo, what link, 2L or 2.5, single or twin scroll, what gas you going to run, what suspension and driveline are you using to harness 400hp?
Well firstly.. It'd be my daily driver ha (: Somewhere between 350 & 400hp would be nice.
Not sure on what link i'd use, Probably TD03 or T3 T4 turbo. It's 2L, I use Gull's Force 10 and probably just factory suspension & driveline at current.
And I wouldn't have an evo.. I'd rather have a Legacy and modify the sh*t outta it to be different. :P
look at CP93MM's build..
and a td03?? rly..? t3/t4 are laggy and not suited on subbies. Try a vf30/34 at the smaller end or a td05 18g or a garrett..
putting out that much power daily and not changing anything except the motor is asking for trouble.. you will lunch your driveline.. and or you when you come off the road going to fast or your car cant handle(you cant handle the car).
I wouldn't actually be thrashing the.. Still just sticking to the speed limit. :P But I'd have a brake to use lol. Probs upgrade them aswell as some point.
And it is being different when you don't see many 02 legacy's puting out 400hp. And also aiming for the 4 & Rotary show n shine.. I've never seen any in there.
the man you want to speak to is Ichiban.
He has a thread recently on here about custom builds to suit individual specs.
Personally(and this is just my opinion) I wouldnt run much more than 200kws atw on a factory block.
You will definately need a 6 speed box or dogbox/worked gearbox to live with this power for a long time.
I was to do make an ultimate daily driven B4 I would look a sourcing a damaged V8 Sti from Japan then swapping out all the goodies, Engine and twin scroll turbo, brembos and 6 speed with DCCD. Then Run it on a G4 link tuned to 220ish Kw ATW. Keep all the nice factory leather and dynamat all the doors and under bonnet to keep it nice and quite.
Comfort+Power+Style = Daily driver WIN ;D
 mattapo said:
for all that work i would be after more than 220
Yeah 220 is pretty conservative but would keep things reliable and fuel consumption wont be through the roof. That figure is probably acheiveable on stock ecu with a reflash, no?
