Top Mount Intercooler TMIC removal legacy
Sean
the hose + clamps that goes from the outlet of your turbo(s) to the intercooler is a bitch the attach and tighten back with the intercooler in the way...
Got help from the guys at MM, to get mine back on..
Simon suggested CRC or engine oil inside the lip of the hose to ease fitting it back on..
yeh had a few problems with mine.but i found removing the strut brace was easyr.heaps more leway to play wth.
 Sean said:
Anyone know how difficult/easy this is? Am about to do it for the first time and abit nervous, any assitance/tips would be greatly appricatied!
Or a walk through?
Car is a Legacy BH5 Twin Turbo.
Just noticed this thread and I have to do the same with mine to replace the knock sensor..
Any tips.. and how long did it take you to do..?
Regards
Paul
best not to use oil based lubricants as they do not dry use K Y jelly its water based and will dry and its another use for it other than smashing off to the playas thread
  • 1 year later...
Use a screwdriver to push the y pipe back on the turbo from the tb side for the win. You can do it in one fluid motion if you do it a few times. Just drop it in angled toward the turbo and tb and level it off easing the hoses into the right place, pop the screwdriver behind the y pipe and its done. V3-6 dont need to remove strut brace if its the same style as stock sti.
 johnny5']
/quote]best not to use oil based lubricants as they do not dry use K Y jelly its water based and will dry and its another use for it other than smashing off to the playas thread
The correct product to use for this is called rubber grease. :-X
