LVVTA
Ninja8)
that document was useful. i was trying to decide whether or not it would make a difference certing my car for adjustables before or after doing the external fuel system, and after reading that doc, it sounds like it doesn't make a difference. excellent.
  • 4 weeks later...
  • Replies 58
hi there mate just got mine certed in whangarei on wednesday at the testing station he just checkd all my mods and was happy all he wanted was to see a warrant check sheet list and failed on a few things for the warrant test but he still got my plate cause it was all fixable like tyres window washers know spare etc if you go for a vtnz test first then show the cert person hel only do the modification checks im so happy mine been of the road for two years
You probably know this already but you need to have drive shaft hoops installed if you have increased power by more than 20%. I'm getting mine certed in Christchurch and I have had a quote for $150 and one for $300 to get them custom made and installed (bear in mind that is with the carpet and seats removed already).
I increaded power by 50% and didnt need cert or anything to state it was single turbo...
 Slidesector']
yes you did... just didn't get pulled up for it, yet (and most likely wont)
 pl0x']
So the certifier's issue?? why doesnt VTNZ pull me up on it? Or is it becasue its certified that VTNZ doesnt care?
Wtf, did you swap the motor or something? That's never come up when I've been talking to my cert guys.
Yeh, we changed to motor to an EJ20K which is more than a 20% increase in power so need to install hoops. I assumed you also needed to install them if your engine mods gave it more than a 20% increase but I could be mistaken.
It's only if you do an engine conversion. But if the engine conversion is the same size, configuration and family as the original you still shouldn't need hoops, as far as I understand it.
Copied from the Engine and Drive Train Standard sheet on the LVVTA website.
Drive-shaft safety loops
2.5(8) A front-engine, rear-wheel drive low volume vehicle that has undergone
an engine conversion, or has had its factory-fitted engine significantly
modified, such that a significant increase in power or torque has resulted,
must be fitted with an effective 360-degree front drive-shaft loop,
mounted within 150 mm rearward of each front drive-shaft universal.
 boon said:
I think it may well just be RWD only... due to the tendency for the car to instantly flip over if the driveshaft snaps and hits the ground at speed.
Subarus would do the same thing if the prop shaft broke wouldn't they. That's why it makes sense to me that this rule would apply to awds too.
I will talk to my inspector to make sure though.
 cods4']
The chances of snapping a drive shaft in an AWD is slim as you have twice as many diffs and wheels driving, snapping axles though is quite common
