window washer resivoir relocation....
smokn4
has anybody done this while still keeping the res in the car somewhere ???
thinking of doing this to clean up the engine bay abit....
does anyone have any pics if they have done this mod??
i want to try moving mine instead of just removing the whole system, dunno where to yet either :D :D
chur 8)
 Firenza said:
well, i know with the early ones (v1 v2) the rear window had a separate reservoir in the rear quarter panel in the boot.
You could try getting on of them, and then routing the pipe work and wiring to the other end of the car.
chur i like the sound of that ill have a look tomorrow.
chur 8)
 smokn4 said:
yea thought about something like that.
but i havent had a good look at how the pump in/on it works or weather or not its mounted inside the res.
thats a nice engine bay you got there to by the way chur
I use a standard pump, just drilled out a hole in the stainless tank to the right size removed the pump from the stock tank and put a rubber oring round it and in it went! all standard pump and wiring apart from the tank and oring! So much easier than relocating to the boot...
i always intended to run mine off the rear window tank, never got round to running a new line though, and had to get a wof so put mine back in for now.
i would put up a pic of engine bay without it but it wont help you cause there is nothing on either of my inner gaurds lol, apart from fuse box.
it does free up alot of space though. and they are damn ugly tanks.
Pimp My Ride - Military Edition August 9th 2006 06:19 This guy is seriously obsessed with the army. He has gone to great lengths in applying a serious military theme to his car, even though it is a two door hatchback! The results are quite impressive. More pics here.
Pimp My Ride - Army Style
Engine
Pedals, including boot accelerator.
Front, including knife gear stick.
In the back.
*These pictures used with permission from ezprezzo.
