STI Pistons
Swindog
depending on model i believe, various info all over the net.
standard sti v1-2
forged sti v3-4
semi-forged diff comp ratio sti v5-6
standard sti v7-
no idea really im just playing keyboard warrior lot of paper research but someone knowledgeable can confirm
sorry bud didnt mean to hijack probably more of a tech post but would be good to know ive spent hours sifting through sh*t on the net trying to work it out. ive dealt with the seller hes a good man been inside a lot of engines just thought he might clarify differences...
continue discussion :) topic split.
standard sti v1-2
forged sti v3-4
standard sti v7-
does standard meean cast pistons?
what exactly does semi forge mean - as in they started to forge it and then cast it while there or was cast and they glued on some forged bits ...
just curious as to what others think of it..
i dont understand semi forged i have no idea its just what people say. some people say its impossible.
sta do semi forged which are cast and forged skirts or some sh*t i really have no idea.
there description as follows:
oe spec cast piston
anodized head, eutectic piston
semi forged, teflon skirts
chrome top rings
i was looking a sti pistons as cheap upgrade for engine when i pull down i over research everything someone who builds ej20s should pass judgement i can only speculate and subaru have no idea they work in a computer which doesnt say forged or non forged...
AFAIK all are cast up till v7 just the STI got a better quality/stregth metal (you cant really semi forge something in my opinion, its either forged or its not......forging is a process afterall) , v7 are forged then the Hyperetetic (sp) cast were v8 onwards. Rods are all the same till v7+.
From what I've read/heard:
V3/4/5/6 sti's only had the "semi" forged piston
V7 got "semi" forged pistons(but better than previous ones) and rods, better crank also
then V8 got hyperetetic cast pistons and a nitrate(d?) crank
Agree
Semi forged are forged but not as strong? (not forged to the same degree maybe??)
it all depends on the ratio of silicon in the alloy casting in making the pistons. the so called "semi-forged" has higher silicon rate than the normal cast pistons which allow it to take more abuse. Because the silicon has harder particles and lower expansion rate it has better wear resistance.
not discriminating and please dont take it the wrong way - but subaru owners are the only people i know of who get all emotional over forged pistons :P
realistically u can make 300 kw on stock cast pistons - because whats the most common failure in pistons ? broken ring lands - what causes it ? detonation
just sayin
that's why Our engine codes are EJ208DWAKE and the etcetera,
not RB20DET,
the det kinda shows the start of whats gonna happen...
just a bit of casual nissan hate.
buuuut, anyways.
If you want to make sure your pistons are forged, buy forged pistons, new.
if you don't really care, then it doesn't matter, does it?
