Android powered ICE
aim
Right so I've got a thread over at AMNZ but I've been asked to post it up here. So here we go;
Here's the original thread;
http://www.androidmobile.co.nz/forum/8-technical/5188-androided-in-car-entertainment-thoughts
I've decided to build a Android powered 'headunit'. Here's the car;
Here's the tablet I'm going to be using;
Amp, Wiring Harness, transformer (+ fuse)
The first interface;
Test fitting;
Here is the power supply wired to the rear of the cigarette lighter - the PCB is tac'd to the dash surround with just a tab or two of hot glue :)
Wiring partially done!
Components for volume knob;
Pentiometer wiring;
Fuse/powersupply assembly, spring cut in half for the harness, and heat shrink for the case.
Testing it in the actual car;
Here it is test fitted - very temporary - might stay like this until after easter.
Here's a video;
^^ at the end it never found my GPS location as I was in the garage - which has a whole other storey above it.
$350US, haha that's probably cheaper than what I've spent lol... But I think you guys are missing the point of a project lol.
Inputs will be 3.5mm and Bluetooth. It's already got 20gb of music so I shouldn't need much more.
  • 4 months later...
Screeech, skid, bang, BOOM!
Police officer: So tell me son, how come you lost control of the vehicle on a straight bit of road?
Reply: Ah, cos I was trying my best to kill that last fucking pig. No wait. wait wait, that\'s not what I meant...............................................
ROFL!
  • 4 weeks later...
 ODB said:
Am trying to jack up parts to do this with an old ipad when I get back.
I will put it vertically though as it fits the GTB "control panel surround" perfectly.
Will have to relocate heater controls but all G.
exactly like the MCM one? i want to do the same.. but i dunooo
 ADIKT']
Yessir.
Exactly like that setup. Might actually get a mate to do it who does installs for a living
Did you run a 4 channel amp for your speakers Aim?
I would like to add a sub at same time to mine. Normally I\'d run rears off factory head unit and bridge for sub but this isn\'t possible with this kinda setup.
Don\'t want to go 5 channel amp as that means can\'t pick up one for nix
 ADIKT']
[quote name='dacerx said:
got all my gear to go in just need to get my tablet sorted and away it goes. i am using the nexus tablet only issue is that you cant put in sd cards for more storage
/quote]Are you putting it into a standard double din?
Nope i have other plan completely
How I ran the speekars in the RX was a 4 channel amp , 2 to the front and the other 2 bridged running the sub :)
now more stealth no sub and just some good fronts being run from a higher capacity amp :)
Looking good dacerx
I\'ve done mine pretty much the same
I\'m using tasker to control screen on/off etc to coincide with power on/off
Running car launcher
Picture of how I\'ve relocated clock and temparature display
And displaying RPM, Volts, AFR and Boost - using a bluetooth OBD II adapter sending data as SSM to ECU Tracker
