Hi Guys
As per title the little digital clock stopped working, i was reading on another fourm that it could just be a light bulb behind it thats gone. Is it an easy fix, auto electrictian could do it fairly quickly ? Any in Tauranga you could recommend ?
Thanks
 NomadGonad said:
Yep checked the fuses first they\'re all good. Don\'t own a soldering iron etc....i\'ll get an auto sparkie to look at it i suppose.
Does your interior light work? They are linked by the same fuse in the engine bay.
  • 6 months later...
 NomadGonad said:
Hi Guys
Thanks
Did you manage to get the clock bulb fixed?
repaired one of these on my brothers bugeye the other day. the current limiting resistors for the backlight seem to cook over time. re-flow a few parts, all sweet.
its a 10min job if you can solder cleanly
Ive been reading up on the bug eye clocks, seems to be a common thing.
Mines a GC8 tho so the clock is next to the fuel gauge on the instrument cluster.
Ha mines the same in my v6, if you look on an angle closely you can see the clock is working, its just the led or backlight thats blown. But of a pain, must get round to fixing it.
mines died totally. but i just pretend I\'m driving a V2... no clock in that puppy!
Must get around to removing the center dash insert altogether and replace with some bling... :P
