Probably a stupid question, hydraulic handbrakes
Bugle
This is just a workaround to get twin pots in the back with the weird wrx/sti/whatsgoingon hubs you have right - not some crazy gymkhana plan
Just get those fake brake covers for the back and just put the 4 pots on the front, problem solved hahaha
Correct, I\'m about a week away from just taking a hard pill, heading to BNT to grab rotors and ripping everything apart calmly dissembling and investigating
sorry if i\'ve got this wrong, but does he just want the handbrake to work after a rear 2pot conversion?
the handbrake shoes still exist on the 2pot setup, attach correct hand brake cables from a wrx and winning?
bah, ignore me. the weird grammar and lack of supporting info means this is probably irrelevant. dunno whats going on with your brakes
Don\'t forget WRX has 2 brake lines running down the drivers side of cabin. You will need to go down to 1 brake line to run the line into the hydraulic handy. Then run it to the back of the car and install a T junction so it goes back to both brake lines at the back... That is unless you wanna install 2 Hydraulic handys, ;) 1 for each side of the rear wheels! :P
 We are borg said:
Or changed to a 3 port unit instead of a 4 port, removal will be better and cheaper.
Surely you\'d need a new ABS computer as well though???
But if you are serious enough to want/need a hydraulic hand brake, the chances are ABS will be hindering you anyway.
 loner']
Yeah new ABS puter, probably new wheel sensors and a whole lot of crap :) but it will be doable
you can block of one of the ports and maybe connect the rear sensors together but I am not to sure if the stock ECU would play nice.
ABS delete would be the easiest thing, Also guessing it is for a Drift/Rally setup so ABS will probably be removed already
