can you run a v8 ecu in a v7?
GetDrift.Com
yes, it\'ll work
BUT
your fuelling and boost maps will be off, your boost limits on the wrx are much lower than the sti. the compression ratios are different too.
also, the v8 has a different MAF sensor scaling, throwing your maps even further out.
my $0.02, just get the standard ecu reflashed. much easier.... quicker, cleaner.
Worth mentioning, when you install a Link G4 plug-in there\'s a jumper you have to swap depending on whether it\'s an STI or WRX. I believe it has something to do with the STI having AVCS heads and the WRX not having them. Might be worth checking.
Ur v7 ecu can easily be retuned almost as good as the other ecu
Depending on mods it will be easier to get it done on the stock ecu
And tuning is cheap
Put up a List of mods u have and what u planning on getting
Depending in the mods u can use stock ecu tune or if it is getting a bit too serious then the hks may be the go
The hks is not tuned by many tuners here in nz so the support is not as good as say a link
If u really wanted to get the hks then u can put a base map for ur v7 on it and it can be tuned from there
If ur car is Jdm and the ecu is from Jdm v8 then yea it will plug in with no wiring change needed
The map on it will be differen and need adjustment tho hence maybe better to start with ur own model base map
Anyway list up ur mods
What area u from
Some non sti have avcs tho need to check as have seen 2000 and 2001 with it so not a year thing.
Thanks guys, I think after looking into it ill get the factory ecu re-tuned.
list of mods im installing atm,
RWD gearbox with exccedy clutch kit and lightend flywheel :)
Apexi AX53B70 turbo
front mount intercooler
15row oil cooler and filter relocation
m&h inlet manifold
70mm thorttle body
alloy crank pulley
STL headers
turbosmart 38mm gate
turbosmart BOV
52mm alloy radiator
apexi afm reacement pipe
Samco induction pipe
zerosports cooling panel
650cc injectors
sard fpr
aftermarket fuel rails
2.5" stainless exhaust
hoping for 260kw atw, I dont really know any at all about subaru\'s i\'m more of a nissan fan so this is all a learning experiance for me.
If anyone has any suggestions let me know, Im not wanting to have to open the engine up at this stage...
 B-MAGIC said:
my 2000 v7 gda has avcs too
with those mods 260kw atw may be abit enthusiastic imo especially,if its still running non sti wrx v7 longblock - just thinking out loud don\'t take it the wrong way, it will pump out a good power figure but may not last long
I\'m with B-MAGIC here. 260kw at the wheels is a serious amount of power to be putting through a non-STi WRX engine.
And if you\'re going RWD? I\'d say go buy a Nissan and make double the power with half the effort.
It\'s mostly the Nz new v7 wrx that had no avcs
The Jdm ones had avcs
Also the non avcs ones had a cat in up pipe as well
Nice list of mods
Should do almost what u want before the afm starts to max
But with the weaker wrx block may we best to keep it lower
Also depends what point ur turbo maxes out
