what could cause this?
tydon
Those are sti pistons
The spark always ignites on compression stroke wnce timing is measured btdc (before top dead centre)
But yea other statements are true - that\'s caused from det - det is like a hammer on the piston - igniting way to early and trying to push the piston down when it\'s forced upwards can cock the piston over - brakes ring lands - although that looks pretty melted also so running pretty lean
 tydon said:
ooooh not good this motor was supposedly doing late 10sec 1/4 Miles according to previous owner and major engine work..
and was apparently not long rebuilt before this happend lol..
Sounds more like it was being flogged to death - probably with a chur boost tap to make it lean out like that ;)
 loganrasti']
[quote name='bc5rs said:
i just ripped into mine and same thing my lift pump died so i had not much fuel and bang slowly ,
/quote]ripped into. Yeh probably a good description of what you would do david
stay focused on the topic and less on being a twat logan
