Wing mirrors?!?!
funkytown
Legacies nope, but other wrx's will fit no probs.
v2-6 are the same so any will do but the v1's like on mine is slightly more square... Only thing thats gives away mine is a v1 to the eagly eye haha
Im 99% confident, I was looking at upgrading my v1 mirrors as I noticed they were slightly squarer then others.. Wasn't till under closer inspection and looking around I noticed that v2-6 had all the same wing mirrors lol Now Im just after a set of thsoe carbon fibre wrc replica mirrors. ;)
It's amazing what little tid bits u learn over the years ;D
sweet so any will fit - my shell and lense is all ok, just the pivot mechanism is screwy and wobbles like shit when you boost and never points in the right direction.
Are they all the same plug fitting and number of wires, someone was saying something about 2 oe 3 wire versions?
Had same wobble, see myself when boost, see nothing when braking.
Put early impreza one onto a V3 sti ($18 thanks pickapart)
Shape is slightly different - and different optics (seems more 'zoomed in') :S my guess is that its flat, where the v3 was slightly curved.
Bolted straight up, and plugged straight in. The only problem, is that you loose the power-retract. (diff between 2-3 wire ones)
arr thats what i wanted to know - mine "power retract".. but have the exact same prob as yours. I was going to pull mine apart to see if i could find the worn out "mechanism" and just replace that, and keep my lense and shell. (if thats even possible).
 TURTLE said:
Does anyone actually use the power retract, i think the only time i did it was when i get the car and i had to push everybutton at least once.
i agree...
i have the same problem as above... pain but thought i was the only person with the issue...
yup every day twice a day as i have a tight as garage and i hvae to close the passenger side to leave me enough room to open the door on my side ;)
my drivers one still retracts now - its just a very loose joint for what ever reason. I need to pull it apart when i return from holiday to see what is worn / broken. I have no idea what to expect pulling it apart so will be a mearn curve - who knows if the little bits are replaceable or not.. are the bits even little replaceable bits at all.. ;D lol
