Thinking of changing my cpu in my legacy b4 will the speedo kms stay the same or will it change.
Think my cpu may have got a lil water damage from the water leak.
Not running good getting loss power rev and speedo stay same but feel it drop in power and jigging about
Speedo is recorded in the dash so no, you're fine
It's more likely the airflow meter or a spark problem but no harm in trying a new ECU
if it pops and backfires under boost it will be spark/coil related (and is common for running rough on idle)
o2 sensor can give "similar" issues to an AFM in my experience
Have you plugged in the connectors under dash to check for CEL?
Driven with the test plugs in?
checked voltage at battery when running?
Also you can take out the ecu and open it up to check for moisture damage, same for the plugs. It will be pretty obvious.
Edited by slystiguy
    574.7k
