On 1/02/2017 at 11:32 AM, sobanoodle said:
I might be wrong, but aftermarket headers on their own only give you an increase at the top end?
The headers really only liven up the top end. They do nothing noticeable in the lower and mid ranges. That's right. It frees up the revs above 5500RPM according to the butt dyno.
11 minutes ago, delta said:
Rear sway bar and new legacy suspensions (I have an outback)
RSB will help a whole lot. Well worth it.
And I'm going to take the thicker I can find + underbody brace :)
45 minutes ago, delta said:
Rear sway bar
Which one have you settled on?
Heard back from Pro Wholesale and they partially have  what I need, plus a wee discount for being a CS member :)
I saw that I can get the Cusco for a good price from RHD Japan, but would be happy with the Ultraracing one as well.
Just depends on the deal I get when I buy it in a month or two.
Good to know for the CS discount.
21 minutes ago, delta said:
Looks like it's not easy to get it right, I don't like the sound of most of these exhausts :P
Mine currently sounds exactly like the car at 3.32
Priced up Cusco too.
  1. It's 20mm vs 21mm
  2. About $40 more expensive, both delivered to my door.
According to RHD Japan the Cusco is 21mm too 9_9
You mean 40$ more expensive for Cusco ?
When I priced it on Pro Wholesale without discount it was more expensive than Cusco, both delivered.
We are shopping for different part numbers and in your case Cusco might be a more favorable option ;)
17 minutes ago, willisnz said:
what $$ are we talking for RSB? I'm interested as well.
Around $300.
That's not bad :) Similar to stock sound but louder I guess.
6 hours ago, sobanoodle said:
Around $300.
Closer to $400 or $500 if you take a 21mm one with rear lower brace.
Nah with the rear lower brace :)
I saw that Ultra racing says that the rear lower brace is mandatory with their rear sway bar, which is why I count it as part of the package and price.
Edited by delta
Was happily running ZeroSports rear sway bar and UR lower brace on my 3.0 without any issues. Don't see how it can be mandatory. I also had a UR rsb for sale, that didn't not look any different from any other BL/BP rsb ;) Apart from being white.
Another thing to note @delta  Make sure you get the right underbody brace. There's two different part numbers: one is for a plain underbody brace, another one is underbody brace with integrated rsb brackets.
I didn't express myself correctly, I meant that you need to reinforce the rsb brackets if you take a thick RSB. I wouldn't install an RSB without reinforcement now that I know about this problem. Seems that some guys abroad even bent the RSB brackets with the stock RSB.
Ultraracing say that you need an underbody brace with bracket reinforcements when you install their RSB pointing you at their one. They're just trying to sell it like @GorGasmSpecB pointed.
Of course you can mix the brands :)
Yeah saw that, won't make the mistake, thx
Edited by delta
1 hour ago, delta said:
Isn't it 20mm hollow on the japanese version and 17mm on the US version ?
GT and 3.0R RSB are not always the same.
Partsouq lists either 20451AG080 or 20451AG021 for the chassis number of my old 3.0, check what part number is for yours.
Was significantly smaller diameter compared to ZeroSports 21mm replacement.
Quote
20.0mm: 20451AG000/20451AG001
19.1mm: 20451AG030/20451AG031/20451AG090
19.0mm: 20451AG010
17.3mm: 20451AG020/20451AG021/20451AG080
15.9mm: 20451AG060/20451AG070
Hmm, partsouq says my car has 20451AG031, which is 19.1, would an aftermarket 20mm or 21mm  RSB really make that much difference? Or is the stock one hollow so not as stiff?
  • Similar Content
