SUBARU Upper Engine Cleaner...anyone used this?
Hailz
  • Replies 121
  • Created
  • Last Reply
Top Posters In This Topic
Guest boostin
 crazy-jono said:
wow mine didnt really have any smoke ???
and it has been serviced at home for last 3 years
It gets driven properly with decent fuel then.
  • 2 months later...
Going to run a can of this through my BL5. I'm actually having trouble finding a vacuum line... The bl5 has a plastic looking intake manifold so looks different to the pics here.
Is the very small line going to the top of the factory BOV a vacuum line I can use? What about the large brake booster vacuum line?
the small vacuum line that goes to the BOV will do for Upper engine cleaner, that heads into the inlet manifold (well does in my car at lest
 QRAF']
[quote name='boostin said:
Someone do a video of it. A nice little "how to", with plenty of smoke at the end. ;D
Edit - found a YouTube video of the smoke.... url=
[/url]
ok mine never smoked that much wow that was extreme.
Neither did mine, mine just let a puff out and that was it haha
Did a can this afternoon for the first time since ive owned the car. I know it says use ANY vacuum hose....but dont use the brake booster vac hose on a H6 as the whole contents end up in one cylinder and your motor hydrolocks.
Then you have to spend far too long removing the air filter housing and other pieces so you can remove the spark plug from the locked cylinder and drain the oily crap out of it.
I believe im the first person to Hydrolock a motor using the upper engine cleaner.
Anyways i got it done properly in the end using the crankcase breather line. Smoked quite a lot. Car seems to run at least as good afterwards
Guest boostin
No you're not. I've done it at least twice at work.
In manuals, stick it in 3rd and push the car back a few metres. It all drains out the open exhaust valve.
Wow i just realised how much of a dumbass i am. I tried pushing the car backwards in gear but it didnt work....now i know why. I was in reverse
I'll post up the results of a DIY day, Going to get the boy around to mine with a can of Upper Engine Cleaner and doing there cars will be interesting in seeing what actually comes out
I did mine about 6 months ago and man the amount of smoke was incredible
  • 1 year later...
i just did it in front of my garage. the smoke clears pretty quickly.... just dont open the garage and walk straight into it after you have done the clean, without airing the garage out.
The fun part was giving it a boost down the street afterwards. mega smoke screen the first time.
 nickch said:
related:
am keen on getting this done.
i read somewhere that its recommended to get an oil change after using the can. is this accurate?
now, gotta find a place in chch where i won't attract attention with white smoke..
Driveway or paddock will do! :D
I used for the first time 2day on my 98 GTB didnt make fark all white smoke compared to what ive seen on some other cars i gess my parts must not been that dirty lol not sure if there was much of a differance after i used it but it can only do good not bad so woth its $23 i ges.crc air flow cleaner really makes a good differance ;D
