Hi,
Legacy 2005 BPE
Can you please help me identify this part on the suspension of my Legacy? Is it the Sway bar bush?
Can I replace this myself?
https://photos.app.goo.gl/gjjDwCxXGY31fNhm6
https://photos.app.goo.gl/oJ9FPiXcxSp5F1yd7
Thanks all,
Donald,
Queenstown
New Zealand
Link to post
Yeah they're your sway bar D bushes and yeah you can replace them yourself, literally unbolt the saddle and the bush has a slot in them so they just slip off. Measure your sway bar and go to your local repco, supercheap or BNT store, they'll give you the part you need. Looking at the pic there is a '20' on one of the bushes so i'd imagine its a 20mm bar, but always measure them just in case.
Edited by Zeus
Link to post
  • Joker changed the title to Legacy BPE Suspension Part
Zeus nailed it. Consider going to a Nolathane bush, although they can be a bit squeaky, especially if they dry out.
As a side note, these can be an easier job if the car is on the ground, or at least has the wheels supported.
Link to post
Nolathane now do greasefree bushes, they're a great improvement on that. Most places should do OE rubber replacements for a fraction of the cost too
Link to post
Join the conversation
Reply to this topic...
  Only 75 emoji are allowed.
  • Similar Content
    • By kamineko
      In lieu of a new Technical board structure being implemented soon, here are the workings for the new FAQ posts to replace all technical stickies, and hopefully most of your searches.
      This is a temporary post because it isn't helping anyone locked away while I'm too busy to finish it.
      Please post additional useful links as a new post for a Mod to add to the list.
      Mods, I've tried to categorise things logically and keep double-ups to a minimum. PM me any questions.
      Cheers,
      kamineko
      INFORMATIONAL
      Documents
      Every JDM brochure - @chappell943 SUBARU PARTS CATALOGUE - @B4 2000
      Workshop Manuals
      Workshop Service Manuals - Stoffa Gen 1 Legacy workshop manual - @slystiguy Gen 3 and 4 workshop manuals - @paulngui Legacy 1998-2003 Service Manual (GEN III incl RSK/GT) - @suubyduuby Workshop manual BE/BH 2003MY. Covers TT 4442 pages by Fuji Heavy Industries - @Rosssub FORESTER 1999-2002 Workshop Manual - @luvmaforzzy pdf Engine manual for a Ej20t Dohc - subaru-mania Vacuum Diagrams and Solenoid Placements for WRX - Swindog
      Gadget Manuals
      Programming Keyless Entry Info All Legacy GT/b's Installation manuals (Timers/Controllers etc) - @Joker Zero Sports Sequential Controller DIY translation - @nncoolg G4 pdf manual - evowrx GFB G-Force 2 Boost Controller Manual  Gizzmo Ibc Manual
      Model Codes & Specifications
      Impreza   WRX Classic Model Codes - kamineko JDM WRX ECUS - kamineko JDM WRX Brake setups - kamineko Factory Power/Torque/Kerb Weights for all GC/GF Models. - thorpy How to decipher model/chassis codes (JDM vehicles) - boostin
      Legacy
      JDM Legacy applied model codes - readosnr
      Legacy BL BP info - subieboy   Forester
      JDM Forester applied model codes
      -readosnr
      Engine
      ECU basics from ScoobyMods including reset & CEL Reading procedures V3/4 Sti Shim under aftermarket valves Part Numbers - @thorpy Intercooler and Other Related FAQ's - @Swindog
      Turbo
      Subaru Turbo System explained - @Stoffa Turbo FAQ's - @Swindog More IHI Turbo specs - @Shale
      Drivetrain
      Manual Transmission Ratios - By @Johnnynz Subaru Gearbox Chart V2 - @GC8E2DD Subaru Gearbox Code Chart
      Electrical
      Full list of fault codes - @boostin Check Engine Light CEL Codes - @kamineko Subaru ABS Fault Codes Power Light Fault Codes (Automatic Transmission) - arsenal69 Wiring guides and pinouts - @ReubenH ECU Pinouts BC5 BG5a WRX (4 plug) pinouts V7 STI ECU Diagram jollygreenmonster.com ECU pinouts Speed sensor pinout - @gotasuby
    • By NZGTB
      I recently imported my dream bh5 in the purple/ blue colour, auto ej206 which I'm fine with, it has 49,000 k"s and upon inspection it has had a centre decat and muffler delete and a back box from zero sports. It's a rev C from 2000 and I'm looking to get a base tune or Remap. I contacted possum bourne here in auckland but they are unable to tune the rev C ecu for some reason? Would anyone be able to point me in a direction of a tuner in auckland? Someone also mentioned on here about project lambda,  I was wondering if anyone has had experience with them and if it's worth it. Thanks guys!
