Just wondering can a single turbo setup work  with a twin turbo ecu ? i am wondering if anyone has done this ?  i understand that the bbod would still have to be plugged in but not use to to control boost control , i am happy with the rev D setup and i have a rev B bh5 which i may just single turbo , just wondering if anyone has done this ?
I'll throw the cat in the bag
I have heard of it yep! but that was about it : they (facebook) did not stick around to tell of reliability or suitability
& not sure why you'd want to actually
V3/4 STI / WRX Ecu plug in & as above has been documented rather well on these forums the steps & tricks to Single T life
most usually got the extra step & get a Link, cos yeah... thats where your going anyway!
I tried this with a single turbo conversion into a 94 Legacy Rs tt early 2000.Car ran fine,but once boost exceeded primary turbo tt boost ecu switched to limp mode.Might be different with your the later model tt ecu,but still requires a lot of work to the solenoid box.Eventually wired in a aftermarket ecu,removed the solenoid box and was able to make changes to ignition timing and fuelling.
well i may have to set a few weekends a side to do this , and i have a single turbo ecu but i think i may have to change the cam and crank pick up trigger wheels as i am sure they are different in the single turbo engines as when i have swapped these engine in the past i have come across this issue i will keep my BH5 twin as it goes very good after reducing the vod to 200 RPM but the bg5 can go single  turbo
The answer is yes you can do it easily if you're using a Rev.D ecu and engine.
The single turbo conversion thread should help and then you can talk to @Pappu1 and he can remap your ECU to work with the single turbo.
the rev d ecu runs the single setup better but you have to have the matching manifold and sensors as they are different to the rev b u have.. also you are right about the crank wheel being different as well so swap to a rev d or v7 type
  • 5 years later...
Okay well years later, I converted the bg5 to revD ECU and dash and engine/gearbox and now way better setup than the ej20R setup with the annoying orange label maf that breaks solder joints all the time, looking for  A4SH701H definitions , as for the ej206 I fixed that by understanding that if closed loop fueling is up the s*** it will affect the open loop so replaced narrow band sensor with a genuine one and a whole different car
