Hi everyone.
My car is getting these codes.
Car is a 2006 Subaru Legacy GT Bp5
B0201 - CAN-HS COUNTER ABNORMAL
B0202 - CAN-HS BUS OFF
B0223 - CAN-HS VDC/ABS NO-RECEIVE DATA
U1202 - CAN-HS BUS OFF (fault location: Comm.Line Failure(ECM/VDC/ABS to Uint) or Integ. Unit Failure)
U1223 - CAN-HS VDC/ASB no-receive data (fault location: Comm.Line Failure(VDC/ABS to Integ. Unit or VDC/ABS Failure)
Can anyone please recommend me any electrician..
Thanks in advance
49 minutes ago, Gripless said:
Where about a are you?
have you checked the fuses related to those systems?
Hey I'm in Botany, East Auckland.
Yes I've checked the fuses..
Most times the AT oil temp flashes and VDC waring display comes on as soon as I start the car but sometimes it's not on when I start the car however it comes on after 2-10min of driving.
It started when I was driving to work one day on the motorway.. was driving as usual like any other days cruising at 100km and it suddenly came on.
Edited by Slepche
  • 4 weeks later...
The abs is part of the CAN system and if there is an issue with that unit then it will
affect the vdc and ecu
- make sure all the wiring is intact and nothing has come loose
- get a abs diagnostic done in case there is an issue with the system
- these systems are fairly bulletproof normally ...
- some codes can be removed but that would be a bandaid as not fixing the actual fault
Bulletproof? Heaps of the Bosch ABS pumps (which have the ABS computer built in) are flaky as f***. They use that "angel hair" wire between the connector and the PCB and they fail at random. I'll wager a shiny internet penny that the ABS computer is f*cked.
Hi thanks for the reply.
I couldn't figure it out so I took it to an auto electrician and got my car back couple days ago.
Indeed it was was the abs computer and they got it repaired.
Thanks everyone for the info
Wish I had these comments earlier
Yes it was a f*cked ABS computer.
Thank you
    574.7k
