Aliexpress random parts
Gripless
Ok so searching for some parts I found other random items, the cover I wanted but he other MAF blank plate I couldn’t find
center console sliding cover $24 shipped
https://www.aliexpress.com/item/1005005912313226.html
alternator pulley dress up cover $50
https://www.aliexpress.com/item/1005005523118969.html
brake booster stop $60
https://www.aliexpress.com/item/1005005666874166.html
short gear shift $55
https://www.aliexpress.com/item/1005002466624862.html
cam tools
https://www.aliexpress.com/item/1005002906222456.html
  • Thanks 1
Cam tools are good to have. I got a set from TM in a hurry that'll surely be aliexpress quality but still work as intended without the massive markup from real brands
That brake booster bracket could be a good way to go. I tried hacking up a cusco one to fit past my WG actuator but never quite worked
I found NZ post seems to hold items a few days and puts them into a single bigger bag for courier to deliver. Previously 4-10 days was normal, now it’s 7-12 days.
tempted by the short shifter but it’s pretty short from factory. I do miss the cable shifter as you can raise them up so they are close to the steering wheel and keep the same throw.
All I got was the sliding cover since one wrecker wanted $175 for whole console!
thats some nice finds. might need to get the pulley cover myself.. was going to DIY one with some alum sheets i got ages ago but been on the backburner for years ? if someone gets the short shifter, would be keen on reviews.. not sure how much better it gets but as you say does feel pretty short already from factory.
I've got a mint condition black grimmspeed one I'll be parting ways with very shortly since it doesn't work with reverse manifold
I'm not ashamed to admit that I bought one of the knockoff turbo blankets off AliExpress last year. Smoked a bit to start off with but hasn't caught fire or anything yet. The only negative  is that it doesn't cover the inlet to the turbo very well.
https://www.aliexpress.com/item/33000085676.html
I also bought some snazzy Subaru logo valve caps too
  • Like 4
Most brands are made in China anyway.
often they skip some finishing  steps. Could be they skipped a chemical wash or final bake to save money.
That or failing some form of quality control. I've purchased a few things as tests that look identical as other ones I've already had besides casting damage etc
