What PSI are you running?
just wondering what your running and with what?
i got a boost controller for xmas and was wondering what i should run it on.
only mods i,v done so far is BOV and pod filter and exhaust.
i was thinking of running it on 14psi
im guessing you have a 96 gtb based on sig..
14-16 is about right.. Is it a two stage controller for the TT system or nah
hey i just got a single solenoid controller.
yes i have a 96GTB
Andrew NR
you can get electronic boost controller for $100
on trade me from HDI aust.
sounds like your manual bleeder needs replacing
 akaynlsn said:
Andrew NR
LOL, the boost controller is only a few weeks old!
Nah, I think it's the turbo 'cause it's whistling quite loud and if I'm going up a hill at 2500 RPM and the revs go up only a tiny bit (say up to 3000 RPM) or not at all with my foot flat to the floor it will hold 12 PSI so there is no leak anywhere. I think it's the turbo being unable to produce boost (well at the levels I want it too) at higher RPM.
my GTB was running 11psi on the GTB block but i done a big end. only replacement i could get was a RS block. now its running at 9.5psi not to sure why.
im hoping my boost controller will fix that and put it up to 14psi
The RS block being a non-bspec, will flow significantly less, which is why you're not able to get the spool to make the boost.
as for me: 1990 BC5 GT (5MT) running 18psi
was going to put the GTB heads on the RS block but didn't know if they would fit.
as i had to do the head gaskets on the RS.
18 psi sounds like fun i will have to save for a piggy back ecu
so i can run that sort of boost.
ing to think maybe my bd5 rs has some sort of aftermarket computer, it looks like a factory ecu but doesnt have a sticker on it, just a sticker saying 'serviced by bla bla bla, removal of this sticker voids all warantys' and it has no speed cut and feels a bit gruntier than my brother in laws bd5, may have to wind up the boost and see what results i get wind the boost up and see what sesu
 Wiretap']
What mod have you done do this BC5 to run 18PSI?
  • 3 weeks later...
 Bazza-NZ']
Its a BC5 in looks only. Its been converted to 3 plug ECU.
I was running 18psi in my BF5 for a while, now running 16.
