Sign in to follow this
Followers 0
Durty-Sanchez
DIY AFM help
12 posts in this topic
Right.. the AFM fixup guide! This is probably most relevant to early-mid 90's AFM's that have no servicible parts in them. The basic idea is that over time the solder joints on the connectors become dry and crack, which makes for a bad electrical connection and sometimes an error code. Even if no code is given, you may experience random loss of power from time to time, which can also be caused by this. Sorry about the blurry photos, it was a crap camera!
Anyway, moving on, you'll need:
Solder
Solder wick/sucker (optional)
Soldering Iron (preferably a hot one)
Knife
Silicon or some other kind of sealant.
1. Locate your AFM on the drivers side of the engine bay. It's attached to the airbox by bolts, and to the flexi-joint pipe by hose clamps. It's probably wise to unbolt the AFM completely from everything, although not necessary. You'll need to unplug it too!
2. After getting the AFM off you'll need to cut through the black sealant that lines the outside of the circuitry housing. The lid is quite deep so be careful when prying it out, I managed to crack the outer casing from prying too hard.
3. After you get the lid off you'll see a copper EM sheilding plate that is soldered down by one side. If the plate is loose then awesome, take it out, otherwise you'll need to remove the solder to get the sheilding plate out. Solderwick is great for this kinda stuff, but i'm sure there's more than one way to skin a cat.
4. Once that's out of the way you can see some of the circuitry involved in the mysterious AFM. Down one side you will see 4-5 connector pins that go from the main plug on the outer casing through to the circuit board (see number 3 on this incredibly blurry excuse for a photo). Usually these are the culprits! It's always best to remove the old solder before re-soldering, but you can probably get away with not doing that.
If you look down at the pins inside the casing you'll see that they are actually made up of 2 pins connected with a solder joint (one from the circuit board, the other from the plug). Heat the joint so the solder is liquid then remove the old solder, then add some more solder as necessary. If you don't have solder removing stuff then i'm sure that re-wetting the joint should be ok. Repeat for all of the pins.
5. You're done! Put the EM sheilding back on and re-solder it to the grounding connection. Then replace the plastic lid and seal it with sealant to keep moisture out. This should conclude your adventures in to the AFM, and should be enough to have repaired it. I've done several of these and never had any more problems with them afterwards. If you're problem persists then you may need to either buy a new AFM or find one on trademe.
Best of luck!
Edited by Joker
Duplicated images from PB to imgur
1 person likes this
Share this post
Link to post
wow, is this not a stickie? it should be! it looks great!
-smurff
1 person likes this
Share this post
Link to post
Fixed, was teh ghey interwebface. You weren't missing much, the pictures are so blurry they look better as thumbnails anyway
1 person likes this
Share this post
Link to post
Awesome thread! ;D
I've got a completely dead AFM that I'm going to muck around with first and if that's successful or it gives me a good idea of what needs to be done then I'm going to attempt to fix my partly faulty one.
I'll take some fresh (and in focus) pics when I pull the completely stuffed one apart.
Share this post
Link to post
New "green label" AFM pics. Feel free to steal and photochop as you see fit.
Share this post
Link to post
I've also heard that "electrical contact cleaner" works wonders on AFMs.
Share this post
Link to post
Will using crc afm cleaner on a 2004 sti screw anything else up?
It can't hurt to try....or can it?
Share this post
Link to post
Saving these images before PB dies / also thread Bump!
The AFM DIY thread is the first and ONLY AFM topic in our Mega FAQ, got any better thread we should add? Let the mods know or post links in the FAQ thread
of if anyone feels like offering updates or better pictures PLEASE DO :P
1 person likes this
Share this post
Link to post
Followers 0
  • Similar Content
    • By Johnnynz
      Based on the APPLIED MODEL number on you VIN plate you should be able to find out, your exact model type.
      Sample (BG5C Legacy)
      And a GC8
      The 7 digit "applied model" code found on the vehicle identification plate inside the engine bay is decoded in the following way.
      Series code G=Impreza S=Forester B=Legacy etc. Body type F=Wagon C=Sedan Engine type 8=2.0L Turbo Year code A=MY93 B=MY94 C=MY95&96 D=MY97 (facelift) E=MY98 F=MY99 G=MY00 Number of doors 2=2 door coupe 4=4 door saloon 5=5 door wagon/hatch Model type 8=WRX 7=RA type E=Sti D=Sti Type R & RA  Transmission D=5 Speed Manual AWD P=4 Speed Automatic AWD
      Hit CTRL + F Buttons in your browser to open the search function, type your Applied Model Code into the search bar and find your vehicle type.
      All information comes from the Subaru Impreza WRX Sports Parts Catalogue
      Dates
      Model of Impreza
      Applied Model
      Option Codes
      Engine type
      Power (PS)
      Shift type
      Transmission Type
      Comment
      11/92 - 09/93
      WRX
      GC8A48D
      BX
      BJ
      EJ
      EF
      EJ20G DW1HD
      EJ20G DW1HE
      EJ20G DW1HE
      EJ20G DW1HE
      240
      Manual
      TY752VB3AA
      First Impreza Turbo
      WRX type RA
      GC8A47D
      EJ20G DW1HJ
      240
      Manual
      TY752VB3BA
      10/92 - 08/93
      WRX
      GC8B48D
      BX
      BJ
      EJ
      EF
      EJ20G DW1HD
      EJ20G DW1HE
      EJ20G DW1HE
      EJ20G DW1HE
      240
      Manual
      TY752VB3AA
      10/93 - 08/94
      WRX
      GC8B48P
      BJ
      EJ
      EG
      EF
      EJ20G DX1NE
      EJ20G DX1NE
      EJ20G DX1NE
      EJ20G DX1NE
      240
      Auto
      TZ102YB3AA
      TZ102YB3AA
      TZ102YB3AA
      TZ102YB3AA
      WRX type RA
      GC8B47D
      EJ20G DW1HJ
      240
      Manual
      TY752VB3DA
      WRX
      (STi Version)
      GC8B48D
      BX
      BJ
      EJ
      EF
      61C
      EJ20G DW2HD
      EJ20G DW2HE
      EJ20G DW2HE
      EJ20G DW2HE
      EJ20G DW2PE
      250
      Manual
      TY752VB3CA
      TY752VB3CA
      TY752VB3CA
      TY752VB3CA
      TY752VB3CA
      First appearance of STi, modified from production WRX
      WRX
      GF8B58D
      PJ
      MJ
      MF
      62C
      EJ20G DX1NE
      EJ20G DX1NE
      EJ20G DX1NE
      EJ20G DX2RE
      220
      Manual
      TY752VB3CA
      TY752VB3CA
      TY752VB3CA
      TY752VB3CA
      First appearance of 5 door
      WRX
      GF8B58P
      PJ
      MJ
      MF
      EJ20G DX1NE
      EJ20G DX1NE
      EJ20G DX1NE
      220
      Auto
      TZ102YB3AA
      TZ102YB3AA
      TZ102YB3AA
      WRX - SA
      GF8B58P
      PJ
      MJ
      MF
      MC
      EJ20G DX1NE
      EJ20G DX1NE
      EJ20G DX1NE
      EJ20G DX1NE
      220
      Auto
      TZ102YB3AA
      TZ102YB3AA
      TZ102YB3AA
      TZ102YB3AA
      Auto transmission fitted after production
      WRX - SA (STI)
      GF8B58D
      BX
      BJ
      MJ
      MF
      EJ20G DW1ND
      EJ20G DW1NE
      EJ20G DW1NE
      EJ20G DW1NE
      250
      Manual
      TY752VB3CA
      TY752VB3CA
      TY752VB3CA
      TY752VB3CA
      As per WRX STi 4 door, modified from production
      09/94 - 08/95
      WRX
      GC8C48D
      BX
      BJ
      EJ
      EF
      BG
      EJ20G DW4HD
      EJ20G DW4HE
      EJ20G DW4HE
      EJ20G DW4HE
      EJ20G DW4HE
      260
      Manual
      TY752VB3FA
      TY752VB3FA
      TY752VB3FA
      TY752VB3FA
      TY752VB4AA
      WRX V-LIMITED
      GC8C48D
      65
      EJ20G DW5HE
      Manual
      TY752VB4AA
      WRX type RA
      GC8C47D
      EJ20G DW4HJ
      260
      Manual
      TY752VB3EA
      WRX type RA STi Version
      GC8C47D
      61C
      EJ20G DW4PJ
      275
      Manual
      TY752VB3EA
      Modified from production WRX
      WRX
      GF8C58D
      PJ
      MJ
      MF
      PG
      EJ20G DW4NE
      EJ20G DW4NE
      EJ20G DW4NE
      EJ20G DW5NE
      Manual
      TY752VB3FA
      TY752VB3FA
      TY752VB3FA
      TY752VB4AA
      WRX
      GF8C58P
      PJ
      MJ
      MF
      MC
      PG
      EJ20G DX4NE
      EJ20G DX4NE
      EJ20G DX4NE
      EJ20G DX4NE
      EJ20G DX5NE
      220
      Auto
      TZ102YB3BA
      TZ102YB3BA
      TZ102YB3BA
      TZ102YB3BA
      TZ102YB3BA
      09/95 - 08/96
      WRX
      GC8C48D
      260
      Manual
      WRX type RA
      GC8C47D
      260
      Manual
      WRX STi Version 2
      GC8C4ED
      BJC
      EJ20G DW5HE
      275
      Manual
      TY752VB4AA
      First full production STi
      WRX STi Version 2 555
      GC8C4ED
      BKC
      EJ20G DW5PE
      275
      Manual
      TY752VB4AA
      Special edition Our Car
      WRX type RA STi Version 2
      GC8C4DD
      C
      XNC
      EJ20G DW5HJ
      EJ20G DW5HJ
      275
      Manual
      TY752VB4CA
      TY752VB4CA
      First full production STi RA
      WRX type RA STi Version 2 V-Limited
      GC8C4DD
      66C
      EJ20G DW5PR
      275
      Manual
      TY752VB4CA
      Special edition
      WRX STi Version 2
      GF8C58D
      61C
      EJ20G DW4NE
      260
      Manual
      TY752VB3FA
      GF8C58D
      62C
      EJ20G DW4NE
      260
      Manual
      TY752VB3FA
      Special edition
      WRX EX
      GF8C5CD
      PJC
      MJC
      QJC
      LJC
      EJ20G DW5NE
      EJ20G DW5NE
      EJ20G DW5NE
      EJ20G DW5NE
      Manual
      TY752VB4AA
      TY752VB4AA
      TY752VB4AA
      TY752VB4AA
      WRX EX
      GF8C58P
      PJC
      MJC
      QJC
      LJC
      EJ20G DX5NE
      EJ20G DX5NE
      EJ20G DX5NE
      EJ20G DX5NE
      220
      Auto
      TZ102TB3BA
      TZ102TB3BA
      TZ102TB3BA
      TZ102TB3BA
      First production automatic transmission
      09/96 - 08/97
      WRX type R STi Version
      GC8D2DD
      81
      83
      91
      93
      EJ20K DW6PR
      280
      Manual
      TY752VB5CA
      TY752VB5CA
      TY752VB5CA
      TY752VB5CA
      First 2 door coupe
      WRX
      GC8D48D
      EJ
      EG
      EC
      EJ20K DW6HE
      EJ20K DW6HE
      EJ20K DW6HE
      280
      Manual
      TY752VBCAA
      TY752VBCAA
      TY752VBCAA
      WRX type RA
      GC8D47D
      WX
      WE
      EJ20K DW6HD
      EJ20K DW6HD
      EJ20K DW6HD
      280
      Manual
      TY752VB5BA
      TY752VB5BA
      TY752VB5BA
      WRX STi Version 3
      GC8D4ED
      EJ
      EG
      EJ20K DW6PR
      EJ20K DW6PR
      280
      Manual
      TY752VBCAA
      TY752VBCAA
      WRX STi Version 3 V-Limited
      GC8D4ED
      61
      62
      EJ20K DW6PR
      EJ20K DW6PR
      280
      Manual
      TY752VBCAA
      TY752VBCAA
      Special edition
      WRX type RA STi Version 3
      GC8D4DD
      XE
      WN
      XN
      EJ20K DW6PJ
      EJ20K DW6PJ
      EJ20K DW6PJ
      EJ20K DW6PJ
      280
      Manual
      TY752VB5CA
      TY752VB5CA
      TY752VB5CA
      TY752VB5CA
      WRX
      GF8D58D
      MJ
      MF
      MG
      MC
      EJ20G DW6NE
      EJ20G DW6NE
      EJ20G DW6NE
      EJ20G DW6NE
      240
      Manual
      TY752VBCBA
      TY752VBCBA
      TY752VBCBA
      TY752VBCBA
      WRX
      GF8D58P
      MJ
      MF
      MG
      MC
      EJ20G DX6NE
      EJ20G DX6NE
      EJ20G DX6NE
      EJ20G DX6NE
      240
      Auto
      TZ102YB5BA
      TZ102YB5BA
      TZ102YB5BA
      TZ102YB5BA
      WRX STi Version 3
      GF8D5ED
      MJ
      MG
      EJ20K DW6PR
      EJ20K DW6PR
      280
      Manual
      TY752VBCAA
      TY752VBCAA
      GF8D5ED
      71
      72
      EJ20K DW6PR
      EJ20K DW6PR
      280
      Manual
      TY752VBCAA
      TY752VBCAA
      Special edition
      09/97
      WRX type R V-Limited
      GC8E27D
      280
      Manual
      Special edition 2 door RA
      WRX type R STi Version 4
      GC8E2DD
      BG
      BL
      EJ20K DW7PR
      EJ20K DW7PR
      280
      Manual
      TY752VB5CA
      TY752VB5CA
      WRX type R STi Version 4 V-Limited
      GC8E2DD
      280
      Manual
      Special edition
      WRX
      GC8E48D
      EG
      EC
      EL
      ED
      EJ20K DW6HE
      EJ20K DW6HE
      EJ20K DW6HE
      EJ20K DW6HE
      280
      Manual
      TY752VBCAA
      TY752VBCAA
      TY752VBCAA
      TY752VBCAA
      WRX type RA
      GC8E47D
      XE
      DL
      EJ20K DW6HD
      EJ20K DW6HD
      280
      Manual
      TY752VB5BA
      TY752VB5BA
      WRX STi Version 4
      GC8E4ED
      EG
      EL
      EJ20K DW7PR
      EJ20K DW7PR
      280
      Manual
      TY752VBCAA
      TY752VBCAA
      WRX type RA STi Version 4
      GC8E4DD
      XE
      XM
      XN
      WN
      EJ20K DW7PJ
      EJ20K DW7PJ
      EJ20K DW7PJ
      EJ20K DW7PJ
      280
      Manual
      TY752VB5CA
      TY752VB5CA
      TY752VB5CA
      TY752VB5CA
      WRX type RA STi Version 4 V-Limited
      GC8E4DD
      280
      Manual
      Special edition
      WRX
      GF8E58D
      MG
      MC
      ML
      MD
      EJ20G DW6NE
      EJ20G DW6NE
      EJ20G DW6NE
      EJ20G DW6NE
      250
      Manual
      TY752VBCBA
      TY752VBCBA
      TY752VBCBA
      TY752VBCBA
      WRX
      GF8E58P
      MG
      MC
      ML
      MD
      EJ20K DX6NE
      EJ20K DX6NE
      EJ20K DX6NE
      EJ20K DX6NE
      Auto
      TV1A2YB6AA
      TV1A2YB6AA
      TV1A2YB6AA
      TV1A2YB6AA
      WRX STi Version 4
      GF8E5ED
      MG
      ML
      EJ20K DW7PR
      EJ20K DW7PR
      280
      Manual
      TY752VBCAA
      TY752VBCAA
      03/98 - 08/98
      22B STi Version
      GC8E2SD
      280
      Manual
      Wide bodied 2.2 litre special edition
      09/98-08/99
      WRX type R STi Version 5
      GC8F2DD
      BG
      BL
      EJ207 DW1PR
      EJ207 DW1PR
      280
      Manual
      TY754VB1CA
      TY754VB1CA
      WRX type R STi Version 5 Limited
      GC8F2DD
      280
      Manual
      Special edition
      WRX type R Limited
      GC8F27D
      280
      Manual
      Special edition
      WRX
      GC8F48D
      EG
      EC
      EL
      ED
      EJ207 DW1KE
      EJ207 DW1KE
      EJ207 DW1KE
      EJ207 DW1KE
      280
      Manual
      TY754VBAA
      TY754VBAA
      TY754VBAA
      TY754VBAA
      WRX type RA
      GC8F47D
      XE
      DL
      EJ207 DW1KE
      EJ207 DW1KE
      280
      Manual
      TY754VB1BA
      TY754VB1BA
      WRX STi Version 5
      GC8F4ED
      EG
      EL
      EJ207 DW1PR
      EJ207 DW1PR
      280
      Manual
      TY754VBAAA
      TY754VBAAA
      WRX type RA STi Version 5
      GC8F4DD
      XN
      WN
      EJ207 DW1PJ
      EJ207 DW1PJ
      280
      Manual
      TY754VB1CA
      TY754VB1CA
      WRX type RA STi Version 5 Limited
      GC8F4DD
      280
      Manual
      Special edition
      WRX
      GC8F58D
      MG
      MC
      ML
      MD
      EJ205 DW1KE
      EJ205 DW1KE
      EJ205 DW1KE
      EJ205 DW1KE
      250
      Manual
      TY754VB1AA
      TY754VB1AA
      TY754VB1AA
      TY754VB1AA
      WRX
      GF8F58P
      MG
      MC
      ML
      MD
      EJ205 DX1KE
      EJ205 DX1KE
      EJ205 DX1KE
      EJ205 DX1KE
      Auto
      TV1A2YB7AA
      TV1A2YB7AA
      TV1A2YB7AA
      TV1A2YB7AA
      WRX STi Version 5
      GC8F5ED
      MG
      ML
      EJ207 DW1PR
      EJ207 DW1PR
      280
      Manual
      TY754VBAAA
      TY754VBAAA
      09/99-08/00
      WRX R STi Version 6
      GC8G2DD
      300
      Manual
      WRX R STi Version 6 Limited
      GC8G2DD
      300
      Manual
      Special edition
      WRX RA V-Limited
      GC8G27D
      300
      Manual
      Special edition
      WRX
      GC8G48D
      280
      Manual
      WRX RA
      GC8G47D
      280
      Manual
      WRX STi Version 6
      GC8G4ED
      300
      Manual
      WRX RA STi Version 6
      GC8G4DD
      300
      Manual
      WRX RA STi Version 6 Limited
      GC8G4DD
      300
      Manual
      Special edition
      WRX
      GF8G58D
      240
      Manual
      WRX STi Version 6
      GF8G5ED
      300
      Manual
      WRX AT
      GF8G58P
      240
      Auto
      Source Credit -
      http://www.catherineandken.co.uk/sti/wrx.html
