Danihellfire
Gull 98 in 2007 legacy GT auto
29 posts in this topic
thus might be why Subaru have pulled the info from their site maybe? (or after Gull Started sponsoring Ben Hunt perhaps)
covering their butt while it was was an unknown or a 'potential risk
Share this post
Link to post
could be as others are saying that the e10 is allowing for it to not knock due to higher knock resistance..
we can adjust the timing to get it running better on 98 or even for e10 to ensure its all running safe.
also check for all leaks etc in case its also a mechanical issue
the reading you pulled out does show there is some room for improvement as there is some knock in the upper mid range that could as well be pulling the power down
also in the low end it looks like the overall IAM reduction may be affecting the proper timing needed hence why its sluggish there
ideally you want the IAM to be 1.00 if the car is setup correctly
fueling wise it seems to want to add a bit more fuel on the top end so may need adjustments there as well depending how much the AFR actually is
Edited by Pappu1
1 person likes this
Share this post
Link to post
My understanding is that once it has learned knock correction, when you change fuels it will take ages to bring the timing back in, so the improvement in performance you've perceived between 2 tanks of gas is almost certainly placebo/butt-dyno results. I think the massive reduction in range and improvement in performance = you just gave it more jandal.
4 people like this
Share this post
Link to post
Seeing as it looks like you had access to BTSSM you could use that to reset the ECU which will reset the Learned Values too, and the IAM will default to 0.5. Then after some spirited driving it should increase hopefully up to 1.0.
Share this post
Link to post
