Boost tap's, yes or no?
Cheap and when set up well they work. Well mine did. Ive got nothing against them.
I heard rumours that youl get earlier spool up with the factory boost solenoid compared to a tap running the same pressure but have never verified it
I get faster spool with the boost tap even when running a few PSI more than stock.
 Andrew NR']
Yup that is my case as well :) Had a boost tap in the Legacy and it was set at 15 Psi,Had way faster spool up compared to no tap,from my understanding it is because it bleeds of boost until the set pressure before allowing any boost to the waste gate, hence the gate does not "creep" allowing full usuage of available exhaust gases :)
 ben-jamminn said:
my gauge is in kg/cm2 and it was running 1.2 kg/cm2 which is 17psi when i got it but i have wound it down to 1 kg/cm2 (14.2 psi) as i thought 17 was too high for standard setup.
Boost taps are fine if used correctly but if you've dropped it back to 1 Bar there's not going to be much difference between using it or the factory solenoid. Good as a cheap way to gain a couple of psi.
17 is fine for an sti
Manual boost controllers are great bang for buck - as said above as long as u don't go crazy but the same can be said of any boost controller.
If your running 14 u may as well return to the factory setup
edit koom beat me to it !
 Qwerty']
17 is ok for a sti? how much is too much?
Can do but I had no issue at all personally on my previous wrx, I never had massive boost spike. Maybe only 1 pound in winter, hence I'd adjust it down slightly. It's best used I find to adjust the boost slightly and well within the limits of the engine, ie not set it just before boost limit.
 swiftbrad said:
isnt the whole boost tap thing a bit dodge as in boost spikes, sure you get the initial setting right but it can fluctuate greatly. Surely you'd go electronic if you spend money on the car anyway and want it done right
I've set mine at 13psi. Boost gauge has never ever gone over this, so I guess if you get a well made one (mine's a turbosmart) maybe it's less of an issue?
