What oil temps do you guys encounter in your cars?
Running the std. oil cooling system (coolant thing on oil filter) what temps does your guys oil get up to when:
1. Thrashing it on the road
2. On the track
And what model etc as well
Rob
 Scoobydoo']
[quote name='Divine said:
I would love to know where to hook up a oil temp gauge on a '91 Legacy.
Easiest and most common way is to get a sandwich plate and install between the block and the oil filter.
On the 2L cars a sandwich plate causes the oil filter to be the lowest part of the engine and sticks out/down,
and possibly one of the worst things to hit.
If your only after oil temp sensor a better solution is to drill & tap the sump plug, cheaper to
Usually not a problem if you use a genuine Subaru oil filter due to their smaller size. But if you use one of the many other brands, they are a lot bigger and do stick down a bit.
 Tony']
or you get the kit that relocates the filter as well..
And assuming you dont have aftermarket headers which also dont hang any lower.
 Tony']
i c didn't know that, come to think of it i was using a other brand filter when testing the sand which plate out...
and yea you could but getting a filter relocation kit to only fit a oil temp sensor is overkill when a sump plug costs $5 max & $10-$20 to get tapped, just swap it in at next oil change.
Edit: Even sand which plate are over kill when just fitting a oil temp sensor, $50ish? still next to wait till next oil change, and even then they are the devil according to some
 Simon C said:
Sandwich plate will allow you to run oil pressure sensor as well.
so will the oil gallery at the rear of the engine,
When mounted on sand which plate engine heat & vibrations can kill press senders (according to instructions, don't know if this is just to cover there ass etc tho) & weight of the oil press can break the screw in piece
I killed 2 oil press senders even when remote mounted, possibly because it wasn't fully secured.
Was just some heavy machinery place in paeroa, just get the thread of your sender (think mine was 1/8 NPT) and ring/go round asking places if they can tap it.
Got a sump plug from pick a part, any subaru one will do
