SUBARU
Impreza WRX STi, 2.0 Litre Turbo Eng., 4WD (1998-2002)
Crankcase
CASTROL MAGNATEC PROFESSIONAL A3 10W-30 or CASTROL EDGE SPORT 5W-30
Service Refill Capacity: 4.5* Litres (See Note 759)
Manual Transmission
CASTROL MULTITRAX or CASTROL SYNTRAX 75W-90
Service Refill Capacity: 4.0 Litres (See Note 176)
Automatic Transmission
CASTROL TQ-DIII
Service Refill Capacity: 9.3 Litres (See Note 12)
Differential
CASTROL EPX 80W-90 or CASTROL SYNTRAX 75W-90
Service Refill Capacity: 1.2 Litres (See Note 132)
Power Steering
CASTROL TQ-DIII
4WD Differential
CASTROL MULTITRAX or CASTROL SYNTRAX 75W-90 - UPDATE Feb 2017 Castrol Multitrax is no longer. The replacement is Castrol Universal 80W-90 and appears the same as the Multitrax (API GL-5)
Service Refill Capacity: 0.8 Litres (See Note 453, 115)
Notes
* Includes Oil Filter
12 Dry fill capacity shown, fill only to full mark.
115 Rear differential.
132 Separate differential only with automatic transmission.
176 Consistently above 0 deg. C, may also use CASTROL EPX 80W-90.
453 May also use CASTROL EPX 80W-90.
759 For severe use or racing, refer Castrol Technical Department.
Edited by Swindog
This ad has been brought to you by Castrol?
Thats what Subaru use from the factory. Except for they use Elf on some of the Sti's is my understanding.
Guest SPANKU
cool thanks for that im doing my change this weekend
Na been researching Castrol oils for karting and race applications and thought it would be good as it shows how much oil you need for each application more than the type of oil. But its good reference material as theres always someone asking how much and what to use.
And best to use A 747 in the kart failing that, Activ2T TTS
  • 2 months later...
Guest S T  E Y E
hey not to sound like a dumb ass or anyhting (been ages since iv owned a subaru) but is the front diff and gearbox oil the same as in wen u fill one up it also fills the other??
im prety sure it is just wanting to make sure
thanks
thanks
not a bad question actually.
In the manual yes its in the same filler / they are joined etc. The 5MT takes about 3.5-4.0L (someone please confirm). The 6MT takes bang on 5quarts or 4.7-8l
The auto has a seperate compartment for main gb and the front diff. The 4AT and 5AT, both take about 1 quart of 0.95l for the front diff and about 3.5l for the main box compartment. You need to drain and fill these seperately.
im quite sure on 3.5l in main compartment for the 4AT but awaiting confirmation on the 5AT
I use valvoline 75w-90 gearoil for mt transmissions from super sheep auto cause its the cheapest i've found (cost 45 slides for 4litre)
Has the same api rating as above (GL5)
And vavoline DX3 for autos as it comes in a 5litre pack as appossed to 4litre and is the same price as castrol 4litres.cheers 8)
  • 1 year later...
just changed to Motul in my 6 speed and lsd.
SL gear 300 75/90 for gearbox and 75/90 FF LSD 2 for the Lsd.($215.00 + GST)
Now uses 1 litre less fuel per 100 km travelled..and the slight whine that was there has also gone.....Ya only get the best results using the best stuff!
Motul for me thanks!
It looks like Gold and it does not "smell" like gear oil...Interesting?
  • 3 months later...
hahaha, I just laughed so hard I almost blew a cornflake through my nose...lol
I\'ve been struggling to find the info for my oils for a DCCD 2002 Sti spec c.
Subaru Wairau Rd has recommended me Castrol Multitrax 80w90 for the front diff/box and SL90 for the rear diff, didn\'t say what brand though.
Thoughts?
Looks like this for the box: http://www.supercheapauto.co.nz/online-store/products/Castrol-Multitrax-Transaxle-Manual-Transmission-Fluid-4-Litre.aspx?pid=1276&menuFrom=60202#Cross
This for the rear: http://www.supercheapauto.co.nz/online-store/products/Castrol-LSX-90-Rear-Axle-Differential-Fluid-4-Litre.aspx?pid=1116#Cross
Is what Winger Subaru have recommended. I\'ve heard Syntrax is better than Multitrax, just can\'t find it.
...and only $50 per litre, I use Motul PA90 in my diff, and redline lightweight shock proof in the gearbox but only to hide my notchy gear change into 5th
That shock proof stuff work well?
  • 2 years later...
Digging up an old thread sorry. Was reading on a US Subaru board that they suggest/recommend when doing your gear oil putting ATF through for a bit as a flush. I dunno? Thoughts please? Anyhow, I'm looking at doing a gearbox flush soon, and just wondering if anyone has some hints or pointers or lessons learned from past mistakes? Cheers all :)
To be honest, I'd just drain and check for any metal fragments. If none and the oil seems 'relatively' clean, just drain it right out, let it sit for a bit to make sure you've got it all, put plug back in and fill it up with good oil.
  • 9 months later...
  • 3 months later...
    574.7k
