Flat battery
aim
 Koom']
Does it die when you are driving around? Or only once you've stopped?
Can't battery shops test them somehow?
Only once I've stopped.
throw a multi metre across it when its running, what voltage do you get
I don't have a multi meter.
is your alarm set to silent? might be screaming it head of on dog-only-hearing volume
Umm... Is that a joke?
check the plug on your alt...might of come off some how...
do you have a volt gauge installed?? if so whats it reading when cars on idle ???
No vault gauge. The plug on the top appears secure.
[quote name='Scoobydoo said:
Your alternator may not be charging. If that's the case, then the most common cause is is worn brushes.
Get a good battery and take it to an auto-sparky so he can check the charging system.
Sometimes easier just getting a 2nd hand alternator.
The problem is getting to an auto Sparky...
