Having your cake and eating it as well...
  • Replies 150
  • Created
  • Last Reply
Top Posters In This Topic
Factor in the v7 being heavier and there will be stuff all difference in the real world Id say. The newer vfs (30,34,36,37 etc) do seem to make better area under the torque curve while making the sameish peak power even when chucked on a non-avcs engine, better compressor designs no doubt.
I always found the 23 had the worst of all worlds but thats my opinion and no one cares about that :P
 WRXONP said:
Yeah im not trying to prove any thing just saying ive made good improvements since that dyno and im just trying to work out if a VF30 is going to give me gains and by the looks of things it will
correct - by gains we mean better power in the mid and low and yielding about the same if a touch less up top than your current turbo.. right ;) but broad brush will be a 'faster' car.
Get a VF34 if you can. I went VF30 -> 34 on my V7 and it was a night and day difference in terms of driveability. VF34 is well spooled at 3000rpm (motorway 109kph cruise RPM), you just squash the throttle and away you go. VF30 is still tieing its shoelaces at 3k.
 funkytown said:
here is the two 'power' curves overlaid. i need corrected figures to do the torque.
can you see the massive hole between the green and blue until over 100?
This is why it, all things being equal, the green one will be faster. Its making more at every point except right at the top - so its long gone by the time you hit peak kw. And they will just shift gears and be right back in the power again.
Altho i argree that a vf3x is a better turbo and also that the green car will be faster.
Its abit hard to make comparisions for the two turbos in these dynos as they have such different boost profiles. I would suspect that if you set the vf23 to make 20psi in the mid range then the difference would be much smaller.
As a general rule a vf3x turbo is capable of 5-10% more flow than a vf23/24
Flow = power.
In the real world on the same type of dyno best i have seen is 220kw for a vf23 and 246kw for a vf34.
Which seems to follow the flow figures.
Flow = power.
Outta curiosity what's the max u seen outta a vf22 bro
about 245kw but that was on a hub dyno - some say they read high.
There was on guy on here Mixja - got 300kw on a hub then could only muster 260kw on a rolling road a week later...
So I don't like comparing hub and rolling road results - be nice one day to do a real test to know one way or the other.
hopefully i can get the 20psi tune done before the next dyno day
