V4 Sti Newbee
dotdog
  • Replies 94
  • Created
  • Last Reply
Top Posters In This Topic
 Qwerty said:
So in short you found bugger all difference between the two powerwise but the vf30 spooled better ?
something like that bro
the spool between the 2 is bugger all (around 100rpm ish)
power wise, im yet to do a final tune on vf22 (planning to run 20 psi hehe)
currently on 18psi tune and they abt the same
vf22 slightly more top end but just like the lag thing - with in reach or each other (171 vs 177 i think)
i think once i get to the 20psi tune (thats the hope but not yet started on it) then i think the vf22 may have a bigger difference that can be looked at as something other than "within reach" type difference
PS. i seen on many forums that vf22 is supposed to support 20psi and some say even more but only time will tell eh
The VF22 has the largest potential for peak horsepower. In other words, in the IHI model range, the VF 22 supports the highest boost levels. It is capable of running up to 25 psi. Because it is a roller bearing turbo, turbo lag is minimal...the boost comes on around 3300 rpm. Expect to max out the VF22 somewhere in the 400-450 hp range.
The VF23 starts the middle ground. It comes on boost around 3100 rpm and is capable of running 20 psi of boost. Expect to max out the VF23 somewhere in the 300-350 hp range.
its not capable of running up to 25psi on a ej20t. period.
While it might run up to 25psi it wil be blowing stupid amounts of hot air - and making less power than at about 18-19psi. that and it will det like shit and smoke your motor REAL fast.
LOL copy and paste much?? google king
a VF22 WILL NEVER get that much bro SERIOUSLY..take a look through the thread in motor and turbo and look at the dyno plots....
anything over 20psi and your going to have some savagely hot intake temps = detonation if not melted piston
one question though... why did the VF22 never come out on a STI but the VF23 did ?? only one way to settle it
While it might run up to 25psi it wil be blowing stupid amounts of hot air - and making less power than at about 18-19psi. that and it will det like s*** and smoke your motor REAL fast.
yay someone backs me up with some facts not what google says :)
 LAZLO said:
hahaha ok yeah that was googled,proof,um come for a ride in my fory,ill put my boost up just for you lol
oh god please do it. 25psi do it for a week and let me know how it gets on.
proof.. put it on a dyno at 15, 19 and 25 psi and report back with results.. thats if your motor lasts a week been raped on 25psi.
lol yeh not a good idea bro youl be maxing it on 18.if your keen for more boost set it at 17 18 and see how she goes,25psi you will be forking outfor a rebuild.funkytown knows his shit.id listen to him 8)
