Amplifier Install CHCH
Flat4
Hey
I have a 2 channel amp that I want to install under the seat and hook up to the front speakers in my Legacy. Have had it sitting around for a few months so thought I should get on to it
Anyone know of someone in CHCH who could install it for a reasonable price?
Chur
 resurrection.inc said:
did yo u manage to get your amp wired up? im an installer in chch that i can do it for ya on the cheap including wholesale prices for the parts (wiring kit) if needed. i back in chch in 2 weeks http://www.trademe.co.nz/Browse/Listing.aspx?id=390698307
Haven't got around to it yet, been busy as.
How cheap? can send me PM me if you like
 Flat4']
[quote name='resurrection.inc said:
did yo u manage to get your amp wired up? im an installer in chch that i can do it for ya on the cheap including wholesale prices for the parts (wiring kit) if needed. i back in chch in 2 weeks url]http://www.trademe.co.nz/Browse/Listing.aspx?id=390698307[/url]
Can do it for ya including a warranty for $80 cash for a 2 channel amp or $100 for a 4 ch amp. (would need splitters) thats why it would be 20 extra thats including the wiring kit of 8 gauge wire
 Timmah']
How much could you supply a wiring kit for a Sub?? Out of curiosity.
depends on what you want really ie size or power. for a 8 gauge kit everything you need would be $40 or for a 4 gauge kit would be $60
  • 4 weeks later...
ill put it in and wire it all up for you for a few beers lol. ive wired heaps including capacitors, extra batteries and 4+ subs etc. i can also get wiring kit for under $20 txt me 027 818 6762 Nate
The way I've most often done it (easiest / laziest way) is use a long screwdriver (or bent out steel coathanger) and make a hole in the rubber cable guide on each side (so it's still protected from any metal edges), and run the cable through that way. Tape the cable to the end of the screwdriver so you can grab it off after you've poked it through.
Can also use some silicon spray to make it slide easier.
Yes you still see the cable, but short of totally removing the door, that's about the next best option.
One door down , one to go.
Its possible to get it through the factory rubber boot , just takes a bit of time and patience.
You need to unplug the loom and pull the boot out at both ends giving you as much length as possible between the door and body.
Then use something stiff but reasonably flexible ( I use some teflon tubing ) to push thru the boot then tape on the cable and pull thru.
Once thats done poke one end into the door and the other end into the car and refit the boot.
All done now. Massive thanks to thorpy for helping me out and for the beer and BBQ to top it off... what a GC
Threading the cable through the door is a bit fiddly but if I can do it anyone can haha. The teflon tubing worked pretty well
  • 3 months later...
