What do I need to change to make my sti run on avgas?
  • Replies 54
  • Created
  • Last Reply
Top Posters In This Topic
 pl0x said:
not going to make F all of a difference unless you have a tune able ecu?
and most tune able ecu's don't need o2 sensors
+1
but why not use something thats more legal..
e85 man
now that stuff is pure gold for running some good numbers and fully legal as well
 Ashton95 said:
I just want to fill my tank up with it lol and see how it goes what o2 sensor do I need?
then why are you asking for opinions, your not going to get what you want to hear?
afaik no one here runs avgas, and certainly not on a roadcar. i've read in my wideband O2 sensor manual that the lead content kills an O2 sensor so maybe you'll need to research what 'kind' you need. even then, its probably incompatible with the factory ecu
go fill up your tank, have fun :)
no o2 sensor will last for very long with it . we only use a wide band o2 for tuning and then it comes strait out after (prolonged running fucks them) . theres no point running it .
you wont go any faster, only difference will be the smell and the hole in your pocket.
unless you tune for it then HELLO ;D
i just swapped back from avgas to 96 (obviously retuned for the 96 tho)
02 sensor is only for cruise anyway .
avgas is cheap if you buy it the right price . its cheaper to make(for the octane rating) and there is no tax on it .
can get it for under $2 a litre if you buy a drum from the right airfield
really how are you goin to get caught ?
 Ashton95 said:
eats away at the valve seals :o
Haven't herd of it killing seals - I know of engine with valve seat damage running av gas
That's the reason old cars that where suppose to run on leaded fuel have to run a additive to run un leaded
 WRXONP']
The lead was supposedly the additive that helped keep old seats from wearing, not the additive that wore out the valve seats. They need the additive to protect the valve seats now that the lead is gone.
[quote name='about tetraethyllead said:
url=http://en.wikipedia.org/wiki/Tetraethyllead#As_valve_wear_preventive]As valve wear preventive[/url]
Tetraethyl lead works a buffer against microwelds forming between the hot exhaust valves and their seats.[2] Once the valves would reopen, the microwelds would pull apart and leave the valves with a rough surface that would abrade the seats, leading to valve recession. When lead began to be phased out of motor fuel, the automotive industry began specifying hardened valve seats and upgraded exhaust valve materials to prevent valve recession without lead
I know of an engine that had a melted piston that was running on avgas. And another that ran a big end bearing that was running on avgas.....
