a question or two
not quite there were NA WRX\'s (newsuba might pop in with details)
year might help, the more details/info we have the more helpful we can bees
what size tires are you running as well
17"s or 16"s etc
Wicked next question is I just reinstalled. My boost solenoid booseting 11 took it for a blat when it hit 5 1/2 6k rev it felt like the engine burpped it hesitated like lose of power and back to normal in 2nd 3rd didn\'t try 4th or 5th as I figured it would do the same
Any ideas?
Regards
Night
17"s or 16"s etc
Bees are cool.
;D
All GC WRX were turbo.
GD-bugeyes had NA WRX sedans - models WRX NA and WRX NB.
 NightKiss said:
Could be but only happens when I hit 11psi at 5k+ revs so high end / load
Regards
Night
just after you changed plugs? ign misfire of some sort check coils etc all bolted in happy and plugs are correct gap
or air leak causing fuel cut
clutch slip toooooooootally different to a misfire
Didn\'t think of that
Don\'t put huge trust in a normal gauge to be thaaaat accurate to be honest, it could be just triggering boost cut I guess - does the ECU record a fault code for this if triggered? (Someone will know)
(off topic lol, the inside of a $20 autogauge and a $200 blitz gauge = identical haha)
I have a fault code 45 still while at idle no code showing when driving pretty sure its because 1 hose is still not installed but the boost solenoids all hooked up tried clearing I did y have the issue when I first reinstalled :S
Not stepper motor goodness.
Grr bloody phone and auto correct lol it didn\'t hesitate or burp when I first reinstalled the solenoid boosted nicely right to rev limit which is 7 I will be intalling new plugs this afternoon the plugs recommended are they the -11s from like supercheap?
I would be looking towards spark misfire before anything else
There\'s a few things which can be at fault but it\'s the most common and easiest to rule out quickly - especially if it\'s only a full boost / high load condition (and you\'re doing plugs anyway haha)
U will need to regap them to.7-.8
Don\'t run 1.1 as it\'s too big for wrx
