Re: Top Notch Legacy Gallery TINTED TAILS DISCUSSION
DacerX
combine tint film / spray with gruntier lightbulbs or elleedees = done
whole car needs to be up to standard first or it just makes you look hellabogan though, right car it can look mint - like the white & black stormtrooper look
Or amber bulbs behind factory amber but tinted lens instead of clear bulbs. Works if your tail lights are faded too as its the colour of the light not the fade on the lens.
I recall vaguely they have to be visible during the day at 100m or something like that, any less any no woffy
the letter of the law says your not allowed to alter the exterior of the lenses
will be covered in this section
http://vehicleinspection.nzta.govt.nz/virms/in-service-wof/general/lighting
edit : found it http://vehicleinspection.nzta.govt.nz/virms/in-service-wof/general/lighting/stop-lamps
Reason for rejection
15. A lamp emits a light that is:
a) not substantially red, or
b) not diffuse, or
c) not projected to the rear, or
d) different in intensity from the other lamp in a pair, or
e) not bright enough to produce a light that is visible from 100m in normal daylight, eg due to modification, deterioration, dirt or an incorrect light source, or
f) is altered, eg due to damage or modification.
Yea my bad Im meaning you will probably pass your warrant. Most cops/inspectors just make sure the reflectors arent covered and lights shine right colour. Big crack down with equivalent of mod squad up here a few years ago that was all they were concerned about.
What you get away with depends how much of a cock you are when you get pulled up.
 TRICKS']
[quote name='nickmcgill said:
This is tempting, My only question would be what is the light output like after applying these.
Anndd will they be warrentable ?
There covers normally take them of for
Night driving I believe
legal requirement Section 12 Modification, retrofitting and repair 12.1 Modification..12.1(3) An overlay must not be applied to a lens if that would reduce the mechanical and optical properties of the lamp below safe tolerance.
curious if its possible to see the indicator flashing from underneath these tinted covers in the daytime?
