STI vibrate at 100km and over
Has anyone ran into similar scenario? Sitting at 80-90km/h the car runs fine but when you put the pedal down and reached 100km/h the body/chassis starts to vibrate slightly. Also note that, the steering wheel is fine, all three pedals are fine as in isn\'t vibrating, only the body/chassis. I have read through previous posts, it seems like I need the following:
1. Wheel balancing
2. Wheel alignment
3. Inner axle joint
Any suggestions? Looking forward in hearing from those who resolved similar situation
 Aaendewy said:
Thanks guys, so I assume it\'s nothing major?
Just do the simple things first... i.e. get the wheels/tyres checked and balanced and a wheel alignment.
Probably nothing major... depending on what your idea of major is... a tyre bulge is not major mechanically
speaking... but major if you get a blowout at speed and drive headlong into a tree.
 loner']
Yeah, sorry, major wouldn\'t be the right word to use. I meant major as in Drive shaft, Inner axle etc. Basically, expensive parts.. that needs to be replace, none major = wheel allignment, balanced etc.
I\'ve had a tyre bulge before, and the vibration comes through the steering wheel.. hmmm
 runrabbit said:
I had a similar prob a while back .. ::)
http://www.clubsub.org.nz/forum/index.php/topic,31801.msg432351.html#msg432351
read down thread a little as it started with a brake issue.
gd luck
Ah thank you, yes, it\'s exactly my issue.. Even at low speed approximately 60-80km/h and at 100km/h the vibration becomes tiny bit worst. I will get my wheels balanced and followed by alignment. Cheers runrabbit.
we had one come into work a while back
and it was the drive shaft bush joint was wearing out and the drive shaft had play in it
Thanks, it could be my wheels, or that. I haven\'t got time to get it balanced and alignment as exams are coming up and assignments still to complete.
let say if I got my wheels balanced + alignment and issue still exist. What\'s the total price for drive-shaft joint replacement?
im not sure an hours labour and a second hand drrive shaft
but could also be brake calipers sticking, check calipers are sliding
but could be anything haha, just do a check list
