Gearbox and Diff oil recomendations
McMatty
I usually fill the rear diff with the rear of the car jacked up to get a bit more oil in there... and allow better access of course.
Also a couple of meters of clear hose with an OD to match the filler hole is best.
Gearbox is easy... just go very VERY slow when filling or it will end up all over the floor when air tries to escape back up the dipstick.
Interesting you say that, last time I filled mine I did it that way and had a few months of it slowly seeping out the breather port until it eventually got down low enough to stop, which happened to be almost exactly at the full point when doing it flat.
I just used to use good old Castrol Universal GL-5, but recently changed to Penrite Pro-gear synth 75W90 (be careful, there's a GL-4 pro-gear, too).
It doesn't get too cold where I am (Sydney) - but I've noticed a significant improvement in cold shifts. Box used to baulk quite a bit until warm, now shifts are smooth right off the bat.
No change in synchro crunchieness that I've noticed.
Yep, I scared myself with my v7, dropped all the oil out of the rear diff on my driveway, no worries. Time to refill, uuhh, cant get top bung oit... Ended up sticking the ratchet into the bung and jacking up the back end of the car on the ratchet to get it to crack. Little bit of stress as it was my only means of transport, and it was getting a bit late on a Sunday avo
