Ok I bought a dereg complete Fozzy [Auto]
67770790_10157431705612456_5765514706026
have removed the AVS & Turbo Timer (lady lost keys & fell out of love with it and got told by the council to dispose of or remove it from the Roadside, along came me!)
I have Spark & fuel and no fire
any ideas or tips? Door chime only comes on when I unplug ign etc
Has sat on the side of the road for 2 years unlocked & locals have had a go at it (Ign pulled out etc) << i believe this may be the main issue
all Lights go on, no stereo though, air con works, I connect the Diagnostic plugs (Black & Green) & get a constant flash of the CEL
I do have the Gravel Express parked nearby for robbing bits off
I am aware this is all hard to see from where you are, just trying the basics for now
next I'll drain tank & pop some fresh fuel in but I'd expect it at least to cough & fart with stale fuel right?
What have you done to confirm you have spark and fuel?
Maybe try whip the return fuel line off and get the fuel pump to run to make sure nothing is blocking fuel flow.
Have you checked spark at each plug yet?
Something super annoying and electrical makes more sense from your description of it's hard last few years haha.
Pulled it off after Filter canister in Bay, got good flow, mate reckoned it was discoloured (where, um is the return line?
& yeah nah only checked one outlet on Coil pack
one theory was Crank / Cam sensor, but I reckon if its got spark, it has signal right?
might pull plugs, or how do I check Injectors are actually working?
I've never really spent time under the bonnet of a Subaru, as odd as that sounds I am not a mech expert (just good at googling / using search button, maybe I should try that LOL
Dunno on an old foz but it'll be one of the three going to the firewall. Try find the reg wherever that is too.
Yea if crank/cam signal is tucked it won't even try spark.
Dunno on injectors, crank it over and then check the spark plugs to see if they're wet maybe? That's how I'd do an initial check. Options after that get expensive or very messy
  • Thanks 1
Old fuel out (about 20L
71954876_10157605277877456_3569556523820
Mower 91 in milk Bottle for comparison
72355824_10157605278027456_1959994100597
and Fresh 98 I put 10L in for comparison
72747783_10157605278337456_4366845038282
Still no go, may need to bleed injectors somehow? / from Filter on?
not getting any return flow from the other two pipes
72843525_10157605278152456_7600447111380
little or big
  • Haha 1
if anything I'd say no pressure? as I had to use the pump prime to get fuel out, (no flow on crank or 'on'
What do you mean by pump prime to get the fuel out? A mechanical primer/line squisher thingy?
Blockage somewhere. Most likely pre rails. If it was after it would cough over but run like s*** as long as the pump is running.
6 minutes ago, Andy_Mac said:
pump prime
ign on / off (prime system)
there was not constant flow and I didnt 'hotwire' the pump
no return fuel either
I can hear the injectors clicking with foot flat cranking
Ahh yeah I get ya now.
Definitely something blocked in front of the injectors then. Try undo some clamps on the supply side fuel hoses to see at what point you don't get flow.
  • Thanks 1
Wait, no return fuel even on prime or just with ign on? Mine only flows on key on (prime). Bridge the fuel pump relay if you want constant flow (pin 30 to 87).
I'd try crank it over a few times, then pull all 4 plugs & see if you think they are covered in petrol, take photos and post them up. Check each one for spark, be ready to replace them. My bet is on plugs assuming fuel is flowing out the return on prime
Pop a vacuum line off the intake manifold and spray something that goes bang in there while cranking it. Brake cleaner works, if it fires and coughs then you have confirmed its fuel issue. If not then you can look more spark / electrical issues? Lots of good ideas here haha i'm keen to find out what it was in the end ?
I wouldn't be surprised if the injectors are just seized
  • 7 months later...
So this was made to go over lockdown : smoked like a biatch!
injectors gummed up....
motor's came out & rescued another GF8
    574.7k
